Mlx90614 IR thermometer
I have a setup that uses parallax's mlx90614 infrared thermometer module with BS2 that I would like have run with the prop rather than bs2. I can get all other components to run on prop, except the IR thermometer. The objects available seem to be for the thermometer component itself, not the module. Has anyone gotten the module to work with the prop? Can you explain it to me if you have step by step as I am not very proficient at spin. Thanks
Fsb
Fsb
