Timing issues with trying to do MIDI output with FullDuplexSerial
__red__
When running the following program:
My Logic analyzer shows that each serial character appears to take 5 seconds to send.
I've run my other code on the same board so i don't think it's a crystal issue.
Anyone have any insight as to my simple mistake?
Red
'* miditest *
CON
_clkmode = xtal1 + pll16x
_clkfreq = 80_000_000
MIDI_OUT_PIN = 20 'MIDI out pin
MIDI_IN_PIN = 21
OPEN_DRAIN = true 'if using the standard MIDI output circuitry TX must be open drain
INVERT_TX = false 'change if required
BASE_OCT = 0 'can go down to -2 or up
OBJ 'include 2 ViewPort objects:
ser : "FullDuplexSerial"
VAR
long onems
PUB main | n, mode
mode := 0
if INVERT_TX
mode |= 2
if OPEN_DRAIN
mode |= 4
ser.start(MIDI_IN_PIN, MIDI_OUT_PIN, 31250, mode)
waitcnt(cnt + clkfreq * 3)
onems := clkfreq / 1000
repeat
repeat n from 0 to 60
send_note(n, 500)
waitcnt(cnt + clkfreq * 10)
PRI send_note(pitch, duration)
'send NoteOn message
ser.tx($90)
ser.tx((BASE_OCT + 2) * 12 + pitch)
ser.tx($40)
'wait for a while
waitcnt(cnt + duration * onems)
'send NoteOff message
ser.tx($80)
ser.tx($40)
Red
80_000_000 with 16x.
I'd delete the thread but there is no delete function that I can see.
I now return you to your previous programming...
Red
