Very sick propeller chip. Update: All better :)
Today I hurt my first prop chip. I am very disappointed it didn't completely survive a hit of 5V on the Gnd pin and Gnd on P24. At least thats what I think I did. There was the obligatory tell-tale sign something was wrong... you know that smell !!!
There have been numerous times I have connected 3v3 & Gnd around the wrong way, and times I have connected 5V instead of 3v3, shorted inputs and outputs, etc, and all these props somehow survived.
However, this one is quite sick. It downloads and programs the eeprom correctly, and then it starts to display data to the serial port. Just when you think all is well, it has a fit and resets part way through the message, and continues to do this. And no, it's not the reset issue with the FT chip.
You know, you really get lulled into a false sense of security that these prop chips are indestructable... Well, not always.
***'s law states that the one that got toasted with 9 V couldn't be that one, but was the one Prop that seemed quite happy with 14+MHz xtals.
The blown chip is now a prime candidate for an internal inspection. Wood chisels at the ready!
It's a testament to the robustness of the chip. I've been smacking them around since 2006 and I still haven't managed to kill one. I have taken out a few boards..
OBC
However, I have built lots of boards for experiments including both hardware and software. IIRC I started in early 2008. So, this is the first prop that I fried.
I did not include the prop I fried a few weeks ago while I was experimenting with my new IR soldering station - the chip got cooked (literally by heat, and left a bubble on the chip and that burning smell too). I have not even bothered (at least yet) to see if the prop works. I haven't taken out any boards yet... now where is that timber (touch-wood)???
So, what happened was that I reversed 5V and Gnd. I have now replaced my onboard 3v3 regulator and all is well! Prop is running again
Good news, better go out and buy that lottery ticket while the luck holds..
Frank
The wood chisel threat always works.
The video generator in cog 0 has decided to not publically show any pixels anymore. (I am pretty sure it has got a lot of pixels stored up for its own needs though)
/Johannes
Most of all the stuff back then was reclaims off of scrap boards and so had some bits not working correctly, I still have that habit now!
I bought TTL chips from what was probably the same supplier - called Bi-Pak or Bi-PrePak, or something like that. I think there were two companies. Before TTL came along, I played about with RTL chips - 3V supply, lots of current and very poor noise immunity. I started building a frequency counter using them, and made a couple of the counter/display stages, using four torch bulbs to display the count for each decade in BCD. I lost interest in it when TTL came along.
