The wiznet5100 is supposed to be the same as on the spinneret schematic, but you'll probably have to move some pins around at least.
I believe the enc28j60 is used on the hive board, www.Hive-project.de. Ingo's code is very good, you should be able to do something with that.
Its in german, I had great success with google translate http://translate.google.com/
ty for ur information i will review the links
