All text now lumped together after forum upgrade
See http://forums.parallax.com/showthread.php?135270-Formatting-test-pls.-ignore&p=1044907&viewfull=1#post1044907All I write now ends up in a single paragraph. This is supposed to be a second paragraph, with a blank line above.This is supposed to be the third line. And below my name, alone on a separate line. That didn't work in the post linked to above, so let's see about this one. Is this a side effect of the announced forum upgrade? Also, quoting and code sections were all messed up when I tried those.-Tor
I've created this separate para to see if this has the same problem.
It works OK for me!
- some of the "smilies" do not insert themselves into messages when clicked on
- odd behavior (I know that's murky) in sentence/paragraph forming when in WYSIWYG editor writing a private message or generating a response to a Forum thread.
Is there any way to roll back that part of the "upgrade" until it can be fixed?
with
any type
of
spacing.
As for the other problems that seem to have developed on this thread.
I haven't seen any issue with smilies on IE and Firefox, I'll check the rest shortly for emoticons specifically.
And about non-breaking spaces not formatting correctly or div style changes; I haven't seen this issue either?
Does anyone have screen pics of these pages that are all mashed up together? It may be I'm used to seeing the site differently than others are wishing/wanting to experience it, so seeing or hearing very specific examples helps me move forward with these 'errors'; otherwise my browsers are all operating within acceptable parameters.
Sorry, can't roll back certain features and keep others; it's all or nothing, and we really enjoy the added security on the back end.
The spacing problem seems to occur between images and before and after <div> sections. Attached is Firefox's rendering of the cited post, which was made before the upgrade. Before the upgrade, the spaces were rendered correctly. My suspicion is that the CSS for <img> and <div> sections does not include any top and bottom margins, whereas before, they did. Within divisions, as in your post above, there is not a problem.
Thanks for looking into this. It's important for those of us who try to create nice-looking presentations in the forum.
and another one to get a blank line as above (that blank line had one of those 'br' tags inserted).
I'm not sure what goes on here after the forum upgrade. The forum certainly isn't using standard HTML form fields for sure. Something that changed must be incompatible with my version of Chromium.
-Tor
Bah that took forever to track down, I think what is now in place should help with layouts:
http://forums.parallax.com/showthread.php?135244-Propeller-Backpack-COLOR-NTSC-Capture
Thanks, Bump!
Still problems for me. In the meantime I've upgraded Chromium to v14.0, didn't help. I have to do manual <br> codes after each line to get a line feed. And for blank lines.
-Tor
