Spinneret...Help!
Hi!
I am having difficulty setting up my Spinneret wit the tutorial from here: http://spinneret.servebeer.com:5000/gstart/setup.htm
My router can't seem to detect it even though I put all of the info in correctly, can you assist me please.
Michael
Michael
There is not enough information in your post.
What is your Subnet mask (router)?
What is your Gateway (router)?
What is your Spinneret IP and port (code)?
How are you trying to access the Spinneret? What are you entering in the address bar?
Do you have an SD card?
Subnet mask: 255.255.255.0
Gateway: 192.168.2.1
Spinneret IP and Port: Not being found by modem, but IP should be 192.168.2.13:5000
I am entering 192.168.2.13:5000 in the address bar in Google Chrome AND in IE. None work, as I said, the Spinneret is not being detected by modem...
Yes I have an SD card, and it is found by the Spinneret and mounted
What do you mean the Spinneret is not detected by your modem? You probably have an Ethernet cable plugged into the Spinneret. Is the other end connected to your router? Is it connected to a switch?
What program is loaded in the Spinneret? Did you see the web server start up in the Serial Terminal?
Can you PING the IP? -> From a command window enter "ping 192.168.2.1".
Please do not alert me through a PM that you have responded. I'll get to your query eventually.
When pinging it in cmd, this is what I get: Thanks!
Michael
What is the make of your modem? You might have to contact the manufacturer or read the manual.
Again stop PMing me!
I messed up on the ping thing, here is the ping for 192.168.2.13.
The modem is a CellPipe modem with Bell in Canada.
Would my gateway be 255.255.255.0 as found in ipconfig or the 'WAN Gateway in the modem'?
Would the host PC be my localhost?
Thanks for your help!
Michael
