Proposed ARM Cortex M4 companion module — Parallax Forums
Peter JakackiPeter Jakacki Posts: 10,193
edited 2012-05-19 10:32 in Propeller 1
Who wants 192kB RAM and 1MB FLASH with a 168Mhz ARM+DSP????? Everybody I would think :cool:
I have scores and scores of Prop pcbs I have designed over the years and sometimes I also marry the Prop with another more powerful "applications" processor. My current design that I am putting through is with the new STM32F407 Cortex M4 CPU which is absolutely packed with you name it. Besides all the memory that it has onboard it also sports USB OTG and Ethernet, camera interface, fast 84Mhz I/O etc.
I'm a PropHead and a Prop fanboy but never to my own detriment, I will use what is appropriate but preferably a Prop. This is for the times when I want (and need) both!
The F4 module can be used on it's own but I can sandwich this to the bottom of the PuppyProp module as one assembly and I have low-profile header sockets that this can still plug into. Sure, that's a lot of I/O in parallel but I look at it like a Co-processor and I decide in software which does what. I'm looking at porting my fast IVOS Forth across to it and it will be even faster. The peripherals and CPU will allow me to do Ethernet, USB OTG, and even MP3 easily, there's even 12-bit ADCs and DACs to make this an all-in-one solution. The use of Forth will allow even those unfamiliar with ARM etc to be up and running within minutes. I expect that the Prop will end up being a peripheral to the F4 :innocent: but it's a very flexible peripheral at that!
Here's a look at a mock-up of the F4 pcb next to the PuppyProp (upside down).
486 x 480 - 79K
    edited 2011-10-18 00:53
    Nice Peter :)
    edited 2011-10-18 01:11
    Ain't nice yet, theres' a lotta lotta work to do...........
    There's a smaller 64 pin device as well as the larger ones so this chip could also be designed to fit "in the corner" of a Prop pcb.
  • TonyDTonyD Posts: 210
    edited 2011-10-18 03:00
    ........There's a smaller 64 pin device as well as the larger ones so this chip could also be designed to fit "in the corner" of a Prop pcb.
    Now, that would be nice.
    edited 2011-10-18 06:00
    TonyD wrote: »
    Cool stuff!
    I had an idea of using the prop for sensors and actuators, and a raspberrypi (ARM1176JZF-S 700-megahertz) ram, communication, crunching etc. Would there be any over lap between you work on the F4 and the raspberrypi?
    edited 2011-10-18 06:02
    I've just ordered one of these http://www.ebay.com.au/itm/Samsung-S3C2440-ARM9-Board-4-3-TFT-LCD-Touch-Screen-/110608092034?pt=LH_DefaultDomain_0&hash=item19c0c18b82
    About the same price as a Dracblade propeller board. The world is moving too fast. I was hoping to build a GUI for the propeller but it seems pointless when there are boards with a touch screen, better display and an operating system or three thrown in as well.
    Time for a paradigm shift in thinking because the Prop can be a very nice companion for this board. For instance, the Prop could attach to the serial port and act as a smart serial router to expand 1 to 8 ports or more.
    The Prop could also interface to a number of SPI A to D and D to A chips to give more real world I/O to that board.
    There are many Prop/ARM synergies to explore.
    [code]
    CPU
    Samsung S3C2440A 400MHz, Max freq. 533Mhz
    SDRAM
    edited 2011-10-18 06:16
    Wow! This is a great idea! If you can tie IVOS Forth into the MultiProp features of PropForth, your new board could sit on an impressive stack of seamless Forth controlled I/O!
    Sign me up!
    edited 2011-10-18 06:32
    Yep, almost what I have been dreaming of since discovering the Prop. A small board with ARM, FLASH, SDRAM, ethernet, USB, serial, SD card etc which also carries one or more Props. The ARM side running Linux so as to be usable as a dev system for the Propellers. The Prop side doing the real-time propellery stuff.
    Closest I have come so far is an almost credit card sized ISEE IGEP ARM board running a version of Debian hooked up to a Propeller board.
    edited 2011-10-18 06:37
    @Drac: The thing with a lot of this ARM11 stuff is that it is more than a single-chip and all this becomes bloatware when you are trying to design a system. Sure this "all on one board" assemblies are great for certain things and I have looked into them too but I want to be able to fit the system into a low-end compact pcb as well and not be dependent upon these SOBs (system on a board :) ).
    @Prof: Once again this is ARM11 stuff you are talking about which is mostly multichip. I've tasted raspberry pie but I have never played with it. They say on their site that's it's a Linux box for $25 which is really good value when you want to run Linux and it sure makes the Prop look like a fish in deep space even trying to compete with this stuff. But I need manageable single-chip devices that I can just use for simple things, real-time things, or far more complex things (except Linux) and not have to drape 100's of megabytes of RAM off it. The IVOS Forth performed extremely well on the older ARM7 platform at 60MHz so I expect the Cortex M4 at 168MHz to go way beyond this level too. No problem with program memory space and the thing is fast enough with enough memory that I can bit-bash VGA signals under interrupts as I did on the ARM7 (but better with DMA) and still have enough memory and processing left over. I can fit a real lot of software in far less than 1MB of Flash so I think I have a lot of headroom with this chip. Still for many tasks I will be using the Prop, but for heavy app crunching and high-level connectively this is way better than say a dedicated chip just for Ethernet.
  • TorTor Posts: 2,010
    edited 2011-10-18 07:03
    Adding ARM seems to be popular.. Altera started mailing out ads for its new Cyclone FPGA setup with a built-in Cortex ARM buddy SoC included on the same chip. The promo says '..that combine an FPGA, embedded ARM processor, and DSP functions all in one integrated chip.'
    -Tor
  • rod1963rod1963 Posts: 752
    edited 2011-10-18 15:47
    I'll buy one. They make a neat combo IMO and is as you stated is better than having a dedicated Ethernet chip.
  • BatangBatang Posts: 234
    edited 2011-10-19 11:05
    STM32 F4 MCU Series Highlights
    Latest ARM Cortex-M4 core
    Pin-to-pin and software compatible with the high-performance F2 series
    7-layer multi-AHB bus matrix and multi-DMA controllers for concurrent execution and data transfers
    Single-cycle DSP instruction support
    Floating Point Unit
    90nm CMOS process technology
    Integrated ST Adaptive Real Time ART Accelerator
    Zero-wait-state program execution up to 168 MHz, and best-in-class dynamic power
    Integrated single-precision FPU boosts the execution of control algorithms, adds more features to applications, improves code efficiency, reduces time-to-market, eliminates scaling and saturation, and allows the use of meta-language tools
    Up to 1 Mbyte of on-chip Flash memory, 192 Kbytes of SRAM, reset circuit, internal RCs, PLLs, sub 1microAmp real-time clock with sub-second accuracy
    4 Kbytes of backup SRAM to save data in standby or battery backup modes
    Typical RTC consumption of <1uA in Vbat mode
    Internal voltage regulator with power scaling capability
    Broad offering of Integrated Development Environments, Meta-language tools, a DSP library, inexpensive starter kits, software libraries and stacks
    Camera interface, Crypto/Hash HW processor, Ethernet MAC10/100 with IEEE 1588 v2 support, two USB OTG (one with HS support)
    Dedicated audio PLL and two full duplex I2S
    Up to 15 communication interfaces (including six USARTs running up to 10.5 Mbits/s, three SPI running up to 42 Mbits/s, three I2C, two CAN, SDIO)
    Two 12-bit DACs, three 12-bit ADCs reaching 2.4 MSPS or 7.2 MSPS in interleaved mode
    Up to 17 timers: 16-bit and 32-bit running up to 168 MHz
    Available in WLCSP (< 4.5 x 4.5 mm), LQFP64, LQFP100, LQFP144, LQFP176 and UFBGA176 packages
    And it is suggested (above somewhere) to use the P8X32A as a peripheral, to do what one would ask?
  • LeonLeon Posts: 7,620
    edited 2011-10-19 11:31
    It does seem somewhat superfluous. :)
    I'm waiting for the Discovery boards to become available from RS.
    edited 2011-10-19 12:04
    I'd use the Prop for video and keyboard and that's about it. The M4 will handle all the rest.
    edited 2011-10-19 17:53
    Just to put this into context as from the specs it appears that the F4 will do everything! Well, this may be true but like like many of the more powerful processors these days the peripheral complexity and learning curve surpasses the CPU itself. Sure it has the capability but it's not a Prop and most of my designs are Prop centric.
    Now there's a thread started by Cluso asking about the features we like most and I know this sounds dumb but while I love a lot of things about the Prop what I like most is the flexibility of the I/O in that they are all identical and any one can be accessed by any cog. This is where other multi-core designs are lacking. When I lay out a PCB, normally it's a chore to decide what alternate function I want from the processor's port pins and then route that pin to where it should go. That is now a hardwired design and if I need a little flexibility later on to tweak the design then it might not be so easy. The Prop is very different and I've become "lazy" in that I use whichever pins are accessible and leave the rest to software. How many times has this proved invaluable I might be able to count but it doesn't stop there.
    Most whiz-bang processors don't work that way and sometimes you can't use certain pins because the functions conflict with other functions etc or there are some other limitations.
    They are a bit like this machine here (credits: Thinking Forth):
    Yes, it seems to do everything but the one variation of it that you want is unobtainable, it's riveted and locked up.....and useless. I know the F4 will be a very powerful single-chip processor in it's own right but it doesn't have the flexibility of the Prop, or the fun factor. Primarily I'm after Ethernet, USB, and fast application space, the Prop will do the rest. BTW, I'm waiting on discovery eval boards too but I have chips already and in the process of pushing out a design (or two).
    edited 2011-10-19 22:16
    Taking another look at the proposed F4 module, it looks you cut it's I/O at the knees rendering it a crippled chip, what gives?
    edited 2011-10-19 22:50
    This module is piggy-backing onto the Prop module but don't worry, I have other boards too.......
  • BTXBTX Posts: 674
    edited 2011-10-20 05:04
    Great Job Peter !!! It's amazing board !!!
    edited 2011-10-20 05:12
    Hey Alberto!!! It would be amazing once I have my boards finished and then the monumental task of porting my software to it. I still haven't decided on a tool chain, I used the free assembler part of the IAR IDE last time.
    So, how are things for you? Good I hope.
  • BTXBTX Posts: 674
    edited 2011-10-20 06:00
    Yeah Peter !! I mean, It will be amazing :) You sure, let us know about your progress in board.
    My things are still running well here, thx you so much !!
    edited 2011-10-22 18:47
    Well my STM32F4 DISCOVERY evaluation boards are on their way and should be here in a day or two while my other boards are being designed. The other feature that I will add to the device is MP3 playback with 7-stage equalizer as this proves to be a breeze for this chip whereas it's altogether impossible for the Prop itself. Once the main functions have been developed then we can treat the chip as we would any other specialized chip such as the Wiznet, Vinculum, MP3, FTDI devices etc except they all rolled into one.
    Now I've got a question for the group, perhaps someone can help me. Does anyone know of an assembler for the Cortex M4 that generates listings and hex files? Most of the compilers out there seem to cripple anything to do with assembler while they try to force the community to accept C/C++ as the standard. All good and well for the majority but we are not all identical robots (yet). 32K is fine as a limit as long as I can generate usable output.
    BTW, C/C++ is an option but I want to develop my IVOS Forth kernel first.
    edited 2011-10-22 23:23
    KEIL
    MDK-ARM Lite Edition
    Programs that generate more than 32 Kbytes of code and data will not compile, assemble, or link.
    From the Keil website http://www.keil.com/demo/limits.asp
    Cheers
    edited 2011-10-23 04:15
    Well, if there is GCC then there is also GAS.. the Gnu Assembler. Often called just 'as'. The cross-compiling environment I use for my (older) ARM Nokia N800 has this:
    gcc --version|head -1
    sbox-arm-linux-gcc (GCC) 3.4.4 (release) (CodeSourcery ARM 2005q3-2)
    as --version|head -1
    GNU assembler 2.16.91 20051213
    and the GNU assembler can generate listings.
    -Tor
    edited 2012-04-22 18:39
    Hey Peter
    I just rediscovered this thread. How is this work coming? Can you run linux and/or GO Language on this Cortex?
    Sal just got the CSP channels going, its a demo, but from now on, the linux workstation thinks it has eight (six actually) cogs out there, and the prop thinks it can have one more BIG cog that has a big bunch of memory. This might mean fun on the Cortex....?
    edited 2012-04-22 22:25
    It's a Cortex chip, so it won't run Linux. You need one of the bigger ARM chips for that.
  • pedwardpedward Posts: 1,642
    edited 2012-04-23 01:05
    Leon wrote: »
    http://www.uclinux.org/ports/
    uClinux support ARM7TDMI, which is an older subset of what the Cortex M4 supports.
    edited 2012-04-23 01:31
    Hi Peter,
    I use CoderSourceryas compler for a ARM7 that may work for You also ...
    I would love to have some companion for the prop. Now I have a GT2449 FriendlyArm thing (SBC2440 Samsung) but it is to big.
    I use it as Filesystem (well with boo webserver) for my Prop....
    enjoy!
    edited 2012-04-23 02:50
    pedward wrote: »
    I meant "proper" Linux!
  • MacTuxLinMacTuxLin Posts: 821
    edited 2012-04-23 06:12
    Leon wrote: »
    What on earth is "proper" Linux? There are so many variants of Linux, as long as it is a derivative of the Linux kernel, it IS Linux. uClinux is a derivative of Linux kernel 2.0 just without MMU.
    edited 2012-04-23 06:17
    Leon wrote: »
    I was going to say "surprising!" and the Cortex must be pretty special, since linux runs on smart phones.
    So now you got curious, what's the difference between "proper linux" as defined by Leon, and uC linux as found on the smart phone? Just in general, in case (my) project ever gets that far.
    Specifically, I only need a linux command line, and the ability to run a terminal program written in GO.
    edited 2012-04-23 06:46
    Full Linux requires an MMU.
    Smart phones don't run uCLinux!
