XBEE Series 1 Speed Issue
Hi
I have 10 series1 xbees in multipoint communication to a master host. When all 10 xbees are sending data back to the master host it is very difficult to act on all commands. Is there a way around this.
Data been send back is always a 2digit number. The host runs through a few if statments on receiving the data.
The baud is set to 9,600.
Any ideas on how to speed up system as I need to catch all data sent back.
If you're using a Propeller, you probably want to use a large rx buffer.
Here's a link to several different sizes of rx buffers in a serial object.
Duane
If more than one XBee is transmitting at once, then you'll need a way of havng each XBee wait its turn before transmitting.
I used the "take turns" method with this project.
Duane
