self balancing bicycle prototype using flywheel(reaction wheel)
Hello everybody,
Well I'm a level 4 mechatronics students from Mauritius and doing my project on a self balanced bicycle which uses a flywheel to achieve this.A better view of it can be seen on:
http://www.youtube.com/watch?v=0312BNqIBFI&feature=related
OR EVEN ON:
http://www.youtube.com/watch?v=d1Uy7bU6TII&feature=related
http://www.youtube.com/watch?v=AvGUuuq7DOE&feature=related
During the past 3 weeks,I've been struggling on calculation of torque(flywheel motor) and I'm stuck.
I have been using the formula T=J*alpha,
where J=moment of inertia and alpha=angular acceleration.
I have assumed overall mass of prototype to be around 2.5 kg,radius of flywheel=5 cm,mass of flywheel=0.5kg,radius of driving wheel=5 cm,max permissible tilting angle=30 degrees.
Could you please help me in selecting my 12V DC motors:flywheel motor(rpm,torque)
Driving motor(rpm,torque)
and flywheel specifications(radius and mass)
and finally if gear box(reduction gear) is needed,its ratio??
Thanking you all in advance.
Best regards
OR EVEN ON:
Best regards
http://www.aqpl43.dsl.pipex.com/MUSEUM/TRANSPORT/gyrocars/gyrocar.htm
Weren't those your videos? If not, you want to duplicate those results?
those are not mine and I'm not sure would be able to duplicate but at least the prototype must remain upright
You should be able to use a gyroscope sensor module to get a reading on how your robot is balancing in the roll axis. Feed this back into a PID loop to figure out how you should adjust the angular velocity of your flywheel to keep your robot balanced.
I hope all of that makes sense
I like the gyro car idea, probably easier to implement than the flywheel on the bike...
