Here is a little idea I thought I'd share
Here is a little idea I though I'd share. You can sometimes mount things like LCDs from the rear of your box (if nothing else is in the way) by using long standoffs . This can make for a cleaner appearance. In this case I also taped a piece of clear plastic from some discarded packaging on the inside to protect the front of the display.
Also, you can buy small sheets of polycarbonate from Home Depot or Lowe's
http://www.seetron.com/mounting.html
Yeah - most project boxes have a taper and dimples where the molded posts intersect the bottom. The boxes I used in my previous post are from Hammond Industries Mfg. and have a textured surface. I put little rubber feet on the front corners to tilt the display up...
The boxes from Radio Shack are pretty low quality IMHO...
http://forums.parallax.com/showthread.php?124495-Fill-the-Big-Brain/page12
