GPS is freezing with push buttons
Hi, I have a circuit containing a Parallax 28146 GPS serial module. I'm able to use the GPS in SMART mode and so I have created 3 buttons on my circuit. If Button1 is pressed then the LCD will display "# of Satellites = " followed by the actual number of satellites. Button2 shows the Lat/Long, and Button3 shows the Time of the Day.
The problem is kind of tough to troubleshoot (at least for me anyway), since I have three buttons when one is pressed it displays the corresponding data, then when a separate button is pressed the LCD is cleared and the proper information is displayed. The problem is every once in a while when I press the buttons there is no data showing on the LCD, as if something is "tied up" and is stuck in a loop or something.
Does anyone know what might be causing this??
I'm adding the code below which is in the majority of the functions:
#define gpsPin1 PORTCbits.RC0 #define gpsTris1 TRISCbits.TRISC0 #define gpsPin2 PORTCbits.RC1 #define gpsTris2 TRISCbits.TRISC1 #define gpsPin3 PORTCbits.RC2 #define gpsTris3 TRISCbits.TRISC2 ANSELCbits.ANSC2 = 0; gpsTris1 = 1; gpsTris2 = 1; gpsTris3 = 1;Loop for button presses:
while(1)
if (gpsPin1 == 1)
Delay1KTCYx(10);
gps = 1;
else if (gpsPin2 == 1)
Delay1KTCYx(10);
gps = 2;
else if (gpsPin3 == 1)
Delay1KTCYx(10);
gps = 3;
else
gps = 0;
switch(gps)
case 1:
getSats();
gps = 0;
break;
case 2:
getLat();
getLong();
gps = 0;
break;
case 3:
getTime();
gps = 0;
break;
ReceiveCounter loop to receive the incoming bytes from the GPS:
while (receivecounter < 1)
if (PIR3bits.RC2IF) //If USART RX buffer is full
if ((RCSTA2bits.FERR) || (RCSTA2bits.OERR)) //If there is a framing error or overrun
receivecounter = 6;
temp2 = RCREG2; // reading RCREG clears RCIF and FERR
if(RCSTA2bits.OERR==1)
RCSTA2bits.CREN=0; // OERRR is reset by clearing CREN
RCSTA2bits.CREN=1; // re-enable continuous receive
else
receivecounter++;
temp2 = RCREG2;
//----------The following code is for Satellites------//
putrsXLCD("# of Sats = ");
Delay1KTCYx(100);
sprintf(idata, "%d", temp2); //print # of Sats
putsXLCD(idata);
The one major thing to note is that in the receivecounter loop the receive counter iterates the same number of times as the amount of bytes it requests. Above I have only added the Sats receive loop, although for Sats, Time, Lat/Long all the receive counter loops are the same except for Lat/Long use a temp[] array instead of temp2 variable, and the receive counter in Sats = 1, Time = 3, and Lat/Long = 5
