Help with connecting to a sensor, please...
I'm stuck. I'm getting old and am having difficulty thinking about things that seemed second nature a few years ago.
I need to connect to a prop a fuel flow sensor that produces a pulse every 5ml. It is powered by +5V and has an open-collector output. A few of my remaining grey cells are suggesting that I need a resistor somewhere, but some of the others are arguing about whether it would be sensor o/p to prop or a pull-up resistor.
Please could someone assist via a suggestion or two?
Many thanks
Hugh
Many thanks
Hugh
You probably need a pull-up resistor.
The Prop 1 can tolerate a small amount of current into the substrate diode to the 3.3v supply. A series resistor of 2.2K may be all that's needed in that case for the input current protection.
Am I wrong here?
Duane
If the sensor is remote and only 5V is available, use a 10k resistor to ground and a 4k7 resistor to +5V to simulate a 3k3 pull-up to 3V3...
