Logic Analyzer questions
Greetings,
I'm looking for opinions / advice on affordable logic analyzers. I've been stalking the USBee and Saleae.
Anyone got any insight?
Use case? Decoding i2c, uart, spi, sniffing data between embedded devices and memory :-)
Red
Red
As for your use case, the Saleae software will automatically decode any protocol that you can specify.
I have the USBee SX and it works just fine. The software will decode "serial, two-wire serial, and SPI".
The Saleae software looks a bit more flexible, especially in dragging data edges and placing markers.
The SX is now about $20 more than the Logic; that bites.
The "cool factor" of the Logic is more than the SX.
I haven't perused the Saleae forums, and have found the USBee forums pretty vacant and sparsely answered.
If I had the need for 8 more channels, I'd buy a Logic mainly due to the lower cost.
*** Don M just commented that trace files can be shared amongst other Logics. The USBee SX software evidently has the same ability.
-Tor
http://www.ebay.com/itm/Oscilloscope-16ch-Logic-Analyzer-Mixed-Signal-Debugging-/230684314665?pt=LH_DefaultDomain_0&hash=item35b5db4c29
My "conscience gene" has been throbbing as this Chinese LA claims to be functionally identical to the USBee DX.
$180 for the equivalent $995.
I think the throbbing is caused by my fear that this product may be a victim of the "outsource your fabrication to China and another factory in China will steal the design and undercut you".
Ethically I'm having a hard time too thinking this as I'm making an assumption based on the reputation of the electronics industry of a country. For all I know these guys may have done the design themselves and made the hardware compatible with the USBee suite of software. There is an open source project that has done this already.
-Tor
Your conscience gene has served you well, my young Padawan.
Man! That box is a direct rip of the USBee product. They've even plagiarized USBee marketing descriptions to build their own.
This is not the analyzer you're looking for...
http://www.phanderson.com/logic_probe.html
ordering: it's halfway down this page http://www.phanderson.com/picaxe
Have a look at his home page http://www.phanderson.com He's an EE professor and has course info and lots of products for sale.
It's just as easy to use the scope.
But it's 800 dollars difference.
I think of I buy one of the smaller usbee devices I'm just going to look at it every day and regret not having the additional functionality... I just can't justify nearly a thousand dollars...
I'll probably just buy the logic 16 although my reasoning is pretty crappy.
Well, you now have a choice to support a (basically) counterfeit product, or the real stuff.
Also remember "you get what you pay for". There's no telling what kind of support structure the Chinese company has...if any.
The Logic 16 is a nice piece of kit. Go for it!
I purchased one of these not to long ago - haven't had time to get into it yet, just played around a bit, but it is a neat device with surprising power "emulates nearly all the features of an HP-16550A State/Timing Logic Analyzer"
For $50 it's worth looking into!
Links:
http://gadgetfactory.net/logicsniffer/
To Purchase:
http://www.seeedstudio.com/depot/preorder-open-workbench-logic-sniffer-p-612.html?cPath=75
Latest software announcement:
http://dangerousprototypes.com/2011/06/10/openbench-logic-sniffer-release-3-08/
...well, I have to admire their honesty:
This open source hardware and software is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. If you can't accept this risk, please do not buy this hardware.
Don't be afraid, it's a fun place - this isn't the only one, you know!!
The main reasons being:
1) Two man crew - supporting small industry.
2) Cross platform support.
3) I was just WAAAAYYY too confused and frustrated with the USBee product selection.
Looks like a good choice. I think I'll look at getting one this winter.
C.W.
I just ordered one from epicTinker. It looks like it should be good fo debugging prop projects.
C.W.
There is alternative software here: http://www.lxtreme.nl/ols/
It is recommended here: http://dangerousprototypes.com/docs/Logic_Sniffer_quick_start_guide
I downloaded and set it up, no device yet, so can only look and wait...
C.W.
I had already loaded the software so install was just plugging it in on my Win7 64 box and letting it load the driver.
I hooked up 4 channels to the /CS, SC, SO, and SI pins of the MCP23S18 on my COSMACog test setup.
I grabbed a quick capture and used the SPI tool to analyze the data. Once I set the MSB/LSB order correctly it showed a perfect data stream.
Lunch is over so no more time to work with it today, I'll give it a good workout this weekend.
C.W.
http://www.aliexpress.com/item/USB-Saleae-24M-8CH-Saleae-24MHz-8Channel-Logic-Analyzer-saleae-24M-8CH-Latest-support-1-1/605379977.html
I wouldn't want to buy one though, I really frown of such a blantant copy, even using the Saleae name.
I really had to do some thinking before I bought the Logic Sniffer, I ended up going with it since the developers made it open source and open hardware.
I try to steer clear of anything that is blatantly violating someones IP, if we don't honor others IP, how can we expect anyone to honor ours.
C.W.
