External Servo Pinion
http://photoshipone.com/shop/index.php?main_page=popup_image&pID=94
Just found this, I had been wondering if anyone sold these, which would allow people to to bigger & better things with servos, after doing the CR mod. Make a monster servo or multiturn sail winch servo.
A tad pricey, but useful if you need it.
Here's one using a Lego gear.
I use this type of setup to drive heavy loads. It keeps a lot of the strain off the servos.
I've also used a RC heli pinion to drive a large gear. Being able to use long screws (3mm) with the metal geared JR servos makes these type of hacks a lot easier.
Duane
http://www.servocity.com/html/48_pitch_hitec_servo_gears.html
I was wondering the same thing. What the heck is there to patent about attaching one more gear to a gearbox?
Maybe they invented the number 48?
I've always thought patenting these things was an exercise in overzealousness, as any infringers are likely to be the Chinese, and it's very hard to combat. The hobby market is sufficiently small that a windfall from an infringement case would be rare . More common is to get a summary judgement and no collection. You're out attorney fees with nothing to show for it.
This in no way says anything about Brian's products. They're well made, and well thought out. I'm just not sure they need to be patented, given the size of the market. That said, should he ever sell his business his portfolio of patents would hike the selling price, and make it attractive for someone like Hitec or Futaba.
-- Gordon
He has essentially taken a gear with an internal spline sized to fit a hobby servo and called it his "invention".
Here is a list of his "inventions".
It looks like for his last 10 patents he is taking common ideas and calling them his inventions.
In reading the first few claims it's more than just a gear as a servo horn, but a complete mechanism that fits outside the servo and incorporates gears and other components.
The "art" of writing patents is so that you can't easily follow what they're talking about, yet still meets the requirements of disclosure. You're required to be specific, but you can obfuscate, too, which then widens the interpretation of what you're claiming. Whoever wrote this patent is a master at obfuscation.
-- Gordon
True for most things, but patent writing isn't one of them. It shouldn't be that way, but it is.
-- Gordon
Could you simplify using a small metal washer on the outside of the gear face? If you have power settings on your laser, you could probably "engrave" a divot that fits the profile of the washer, for a more flush appearance.
I recall there was a guy (Bruce Filner, I think) that used reduced power modes to do limited depth cutting for the splines, effectively keeping them from piercing all the way. Always seemed like an interesting approach, but I have no idea how effective it was. I never saw an example of a finished product.
-- Gordon
