Linear Actuator
Hi. Im very new to working with the basic stamp. I would like to know if i can connect and control a Linear Actuator w/ feedback using the BOE. The actuator is 12v (500ma running, 10A stall). I have a 12v power supply connected to the BOE so i was hoping i could use the unrequlated 12v power directly from the BOE. If that is true do i need some kind of driver? Finnaly, can i program the actuator using Pbasic. Any help would be much appreciated, even if it is just direction to more information. Thanks
Others just move to their limits based on applied power polarity, they can be controlled using a DPDT switch or relay: http://www.firgelli.com/pdf/DPDT_Switch.pdf
What brand are you using?
So yes, you still need 2 relays. You can either use one SPST (on/off) and one DPDT (reversing) relay, or use two SPDT relays, a little slicker IMHO. You can use the circuit attached with 5V relays, but leave out the red diodes and make a wired connection in their place. Your actuator goes where the motor (M) is.
