Programming Propeller Chip With RS 232 port
Hi
I am trying to program propeller chip with the help of a RS 232 port. I have made the connect accoring tho the sche,matic given in[1]
but the also my PC is not detecting any Chip connected.
Do i have to connect MAX232 IC(level converter) or is the circuit given[1] is only required?
Also i have a USB to Serial converter cable can i just use this cable rather than using a prop plug? I have to give my project in 14 days and shipping of prop plug is not possible in the mean time.
[1]http://www.parallax.com/Portals/0/Downloads/docs/prod/prop/SerialtoPropeller.pdf
Re-check your wiring and then check it again, and make sure your serial (COM) port is good.
