PropBasic & Libraries
doesn't PropBasic support nested libraries?
This code works ok, no errors from PropBasic neither from Homespun:
Std.Lib:
Std.Lib as before,
Dog.Lib:
HomeSpun To RAM
Homespun Spin Compiler 0.31d
parsing C:\Work\Propeller\PropBasic\Programs\DogM162.spin
Error: C:\Work\Propeller\PropBasic\Programs\DogM162.spin (106, 19): Unexpected mov
mov __temp1,MOSI ' shiftout MOSI, MCLK, MSBFIRST, __param1
Where is my error?
Thanks, Friedrich
Std.Lib:
' ---------------------------------------------------------------------- ' File...... Std.lib ' Author.... fgvissel 10.10.2011 ' Library Std, Delay Subs & idx vars ' ====================================================================== ' ----- External Libs -------------------------------------------------- ' ----- Conditional Compilation Symbols -------------------------------- ' ----- Constants ------------------------------------------------------ ' ----- IO Pins -------------------------------------------------------- ' ----- Shared (HUB) Variables (Byte, Word, Long) ---------------------- ' ----- User Data (DATA, WDATA, LDATA, FILE) --------------------------- ' ----- TASK Definitions ----------------------------------------------- ' ----- Local Variables (LONG only) ------------------------------------ t1 var long 'those are temp vars for temporary use t2 var long 'mind they are global t3 var long t4 var long t5 var long ' ----- SUB and FUNC Definitions --------------------------------------- DelayMS SUB 1 DelayUS SUB 1 '{$CODE} ' ----- SUB and FUNC Code ---------------------------------------------- SUB DelayMS pause __param1 ENDSUB SUB DelayUS pauseus __param1 ENDSUB '{$TASKS} '------ Task Code ------------------------------------------------------ '=======================================================================Main Program:
' ---------------------------------------------------------------------- ' File...... DogM162.pbas ' Author.... fgvissel 09.10.2011 ' for Propeller with 6,26 MHz X-tal ' Uses only Std.Lib, Dog Subs local ' ====================================================================== ' ----- Device Settings ------------------------------------------------ DEVICE P8X32A, XTAL1, PLL16X XIN 6_250_000 ' ----- External Libs -------------------------------------------------- '{$ifndef StdLib} '{$define StdLib} LOAD "C:\work\propeller\propbasic\library\Std.Lib" '{$endif} ' ----- Conditional Compilation Symbols -------------------------------- ' ----- Constants ------------------------------------------------------ ' ----- IO Pins -------------------------------------------------------- D0 Pin 0 'Live signal RS Pin 20 High '<--> EA DogM16x Pin 39 CSB Pin 21 High '<--> EA DogM16x Pin 38 MOSI Pin 23 Low '<--> EA DogM16x Pin 28 MCLK Pin 22 High '<--> EA DogM16x Pin 29 ' ----- Shared (HUB) Variables (Byte, Word, Long) ---------------------- ' ----- User Data (DATA, WDATA, LDATA, FILE) --------------------------- ' ----- TASK Definitions ----------------------------------------------- ' ----- Local Variables (LONG only) ------------------------------------ delta VAR LONG target VAR LONG counter VAR LONG ' ----- SUB and FUNC Definitions --------------------------------------- Dog_OutChar SUB 1 Dog_OutString SUB 1 Dog_Init_162 SUB ' ====================================================================== PROGRAM Start Start: Dog_Init_162 Main: Dog_OutString "0123456789ABCDEF" low RS 'Command Dog_OutChar $C0 'set RAM address $40 Dog_OutString "Line 2" delta = _FREQ /10 target = cnt + delta do toggle D0 waitcnt target, delta loop END ' ----- SUB and FUNC Code ---------------------------------------------- SUB Dog_OutChar shiftout MOSI, MCLK, MSBFIRST, __param1 DelayUS 50 ENDSUB SUB Dog_OutString t1 = __param1 'hub address of string t2 = len __STRING(t1) high RS 'data t2 = t2 - 1 for t3 = 0 to t2 RDBYTE t1, t4 Dog_OutChar t4 inc t1 next ENDSUB SUB Dog_Init_162 DelayMS 75 'Init DOGM-162 LCD for 5V, 8bit SPI operation low CSB 'Chip select, Sync with Propeller low RS 'Command mode for LCD Dog_OutChar $38 Dog_OutChar $39 Dog_OutChar $1C Dog_OutChar $74 Dog_OutChar $52 Dog_OutChar $69 DelayUS 250 Dog_OutChar $0F Dog_OutChar $01 'Clear Display DelayMS 2 'End of Init ENDSUB ' ----- TASK Code ------------------------------------------------------ ' ----------------------------------------------------------------------But if I build another library for the dog LCD code:
Std.Lib as before,
Dog.Lib:
' ---------------------------------------------------------------------- ' File...... Dog.lib ' Author.... fgvissel 10.10.2011 ' Library Dog, Driver for EA_DogM16x LCD ' Uses Std.Lib ' ====================================================================== ' ----- External Libs -------------------------------------------------- '{$ifndef StdLib} '{$define StdLib} LOAD "C:\work\propeller\propbasic\library\Std.Lib" '{$endif} ' ----- Conditional Compilation Symbols -------------------------------- ' ----- Constants ------------------------------------------------------ ' ----- IO Pins -------------------------------------------------------- RS Pin 20 High '<--> EA DogM16x Pin 39 CSB Pin 21 High '<--> EA DogM16x Pin 38 MOSI Pin 23 Low '<--> EA DogM16x Pin 28 MCLK Pin 22 High '<--> EA DogM16x Pin 29 ' ----- Shared (HUB) Variables (Byte, Word, Long) ---------------------- ' ----- User Data (DATA, WDATA, LDATA, FILE) --------------------------- ' ----- TASK Definitions ----------------------------------------------- ' ----- Local Variables (LONG only) ------------------------------------ ' ----- SUB and FUNC Definitions --------------------------------------- Dog_OutChar SUB 1 Dog_OutString SUB 1 Dog_Init_162 SUB '{$CODE} ' ----- SUB and FUNC Code ---------------------------------------------- SUB Dog_OutChar shiftout MOSI, MCLK, MSBFIRST, __param1 DelayUS 50 ENDSUB SUB Dog_OutString t1 = __param1 'hub address of string t2 = len __STRING(t1) high RS 'data t2 = t2 - 1 for t3 = 0 to t2 RDBYTE t1, t4 Dog_OutChar t4 inc t1 next ENDSUB SUB Dog_Init_162 DelayMS 75 'Init DOGM-162 LCD for 5V, 8bit SPI operation low CSB 'Chip select, Sync with Propeller low RS 'Command mode for LCD Dog_OutChar $38 Dog_OutChar $39 Dog_OutChar $1C Dog_OutChar $74 Dog_OutChar $52 Dog_OutChar $69 DelayUS 250 Dog_OutChar $0F Dog_OutChar $01 'Clear Display DelayMS 2 'End of Init ENDSUB '{$TASKS} '------ Task Code ------------------------------------------------------ '=======================================================================Main Program:
' ---------------------------------------------------------------------- ' File...... DogM162.pbas ' Author.... fgvissel 09.10.2011 ' for Propeller with 6,26 MHz X-tal ' Uses Dog.Lib ' ====================================================================== ' ----- Device Settings ------------------------------------------------ DEVICE P8X32A, XTAL1, PLL16X XIN 6_250_000 ' ----- External Libs -------------------------------------------------- '{$ifndef DogLib} '{$define DogLib} LOAD "C:\work\propeller\propbasic\library\Dog.Lib" '{$endif} ' ----- Conditional Compilation Symbols -------------------------------- ' ----- Constants ------------------------------------------------------ ' ----- IO Pins -------------------------------------------------------- D0 Pin 0 'Live signal ' ----- Shared (HUB) Variables (Byte, Word, Long) ---------------------- ' ----- User Data (DATA, WDATA, LDATA, FILE) --------------------------- ' ----- TASK Definitions ----------------------------------------------- ' ----- Local Variables (LONG only) ------------------------------------ delta VAR LONG target VAR LONG counter VAR LONG ' ----- SUB and FUNC Definitions --------------------------------------- ' ====================================================================== PROGRAM Start Start: Dog_Init_162 Main: Dog_OutString "0123456789ABCDEF" low RS 'Command Dog_OutChar $C0 'set RAM address $40 Dog_OutString "Line 2" delta = _FREQ /10 target = cnt + delta do toggle D0 waitcnt target, delta loop END ' ----- SUB and FUNC Code ---------------------------------------------- ' ----- TASK Code ------------------------------------------------------ ' ----------------------------------------------------------------------PropBasic compiles ok, but homespun complains:
HomeSpun To RAM
Where is my error?
Thanks, Friedrich
I just looked at the spin file and the dog.lib subroutines are there twice.
If I delete the first set all is well. I have attached all the test files.
TestLib.zip
Cheers, Fried
