Program for a newbie?
Dav
Hi, I'm trying to program a boe-bot for the first time but I don't know how to get started.
I'm currently trying to make it go around in a square, however, I can't get the angles right and it keeps on spinning in a circle.
Can anyone help me?
Oh, I almost forgot, I have the bs2 boe-bot.
Can anyone help me?
The BoeBot does not have really fine control of movement. To go in a square, the BoeBot first has to go straight forward for a little while with both servos turning at the same speed in opposite directions. Then, both servos have to turn at the same speed in the same direction for a short time depending on which way it has to rotate. The whole thing has to happen for each side and corner of the square. As is usual for programming problems (and solutions), you have to break it down into steps, get each step to work separately, then get them to work together in the right order. The "Robotics with the BoeBot" tutorial goes into some detail on how to get servos to work the way you want them to.
You're not going to get a good square, but with careful attention to timing, you should get something close. To get finer control, you'll need something like the wheel encoder that Parallax sells for the BoeBot. That still doesn't address the problem of slippage on the floor.
If you want more specific help than that, you'll have to provide a lot more information. One thing would be to attach your source program to a reply. Click on the "Go Advanced" button and look for the Attachment Manager button.
