Digi XBee WiFi module
I received the dev kit from Digi and have played with it just a bit. It includes 2 WiFi Xbee's and 2 USB interface boards. The tutorial for getting them to communicate to one another through your wireless network was pretty simple and straight forward. You bring up a terminal window for each module through the XCTU program and whatever you type in one shows up on the other.
Here's where I run into a road block. I don't see how I can use them as a server similar to the Spinerret. Granted I don't quite understand all there is to know about TCP / IP. The devices work well as a wireless serial cable replacement but I don't see how to access them from a webpage.
Here's the manual for the module: https://docs.google.com/viewer?url=http%3A%2F%2Fftp1.digi.com%2Fsupport%2Fdocumentation%2F90002124_C.pdf
A normal XBee can handle wireless serial communication fine. What do these do that a normal XBee can't?
Thank you Don and Mike to sharing what you've learned about these. I almost purchased a development kit when I saw these being discussed last week (or so). So far, (based on what I just learned here) I'm glad I didn't order the kit.
Duane
Robert
NTSC?
wikipedia.org/wiki/NTSC
wikipedia.org/wiki/PAL
PAL vs NTSC
www.michaeldvd.com.au/articles/palvsntsc/palvsntsc.asp
Just got the RN-174 development kit today and the Digi WiFi kit too.(The Digi kit took forever to get)
The Rov.Net.WiFi RN-174 will do the TCP/IP stack from what I have read so far.(force an IP address to the RN-174 WiFi module)
The Digi WiFi not so much.(I may return this as I have not opened it yet) But I'll read-up a little more on it first.
The Rov.Net. WiFi development kit (RN-174) comes with no paper work.You must down load all the DOC's from their site.About 120 pages worth.
Short on time, But I'll report back when I get something going.
