Basic Stamp suddenly stops working
I am using the BS2p24 and BS2 to run a data telemetry board. Every once in a while, the basic stamps stop responding. I pop in a new one and it works, but somehow the other stamp has died. Not sure what I am doing to them, sometimes a certain stamp will run forever with no problems, others just stop all of a sudden after working well for weeks or months.
I am powering the board from a 24 V DC supply that is regulated to 5V by a LM7805. Once I sent the stamps back to Digikey where I ordered them and they said there was nothing wrong with them. Every once in a while a stamp that has gone "bad" will come back. It will have stopped being identified by the software, and when I put in a different stamp that one is identified with no problem. I will label the bad one, check it again using the BOE board, and still no identification. But I will put in on a shelf for a month and it will work again. On other occasions the same stamp will be dead forever.
When I run the identification on the software, the Loopback and Echo says: Yes on both. The only thing I could think of is that the power is low and the ones that come back to life are finally getting the right power. As for the ones that stay dead forever, I'm not sure how I killed them.
Any advice would be helpful. I've attached a pdf of the schematic.
1. You're supplying your regulated +5V to the Stamp's Vin pin, which needs at least +5.5V for proper operation. The +5V should go to the Vdd pin instead.
2. Your schematic doesn't specify what kind/size caps you use on the regulators. Can you elaborate?
Make up a complete schematic of your setup and either post it here or at least send it to Parallax Tech Support.
Also pursuant to the Vin/Vdd issue (but probably not relevant to the Stamp burning out), your ADCs are not both powered the same. On one, Vcc and Vref come from the Stamp's Vdd output, which will be too low; on the other, Vcc comes from +5V and Vref from Vdd.
