nice little h-bridges
Any suggestions for particularly nice h-bridges for interfacing to the propeller, currents less than an amp are fine. Something without much external circuitry preferred. No size limits, SMT is OK.
Graham
Graham
The Vishay part looks great, actually the selection seems much better than I remember when I looked in the past, feel a bit silly asking now. Possibly it was because I was trying to find ultralight stuff.
Graham
The Vishay part was the driver of choice for many prosthetic hands to control Open Close and Rotation in our designs 15 years ago. For 1Amp you can't beat it, but you might want to put a metal slug to dissipate the heat if you run close to 1 Amp for long periods.
The Vishay chip looks excellent and there is a slightly newer version that allows switching rates up to 500khz. I'll be using them well below the rated current so I fairly happy they will do the job and should be rather neat.
Cheers,
Graham
Then there is this...
http://www.parallax.com/Store/Accessories/MotorServoControllers/tabid/160/ProductID/66/List/1/Default.aspx?SortField=ProductName,ProductName
Graham
