GPS Datalogger Kit with XBee
Basically I am trying to make a program that will send out GPS data to another computer using an XBee RF Module. The GPS program that I use is the one written by Chris Savage. Now, I just need to send the coordinates or possibly the KML file using the XBee. However, I am clueless to how should i write out the program to tell the XBee that it should send out the GPS data. Also, when I try to add some simple lines, such as SEROUT... an error 124: Data occupies same location as program will be shown.
Is there any solution to this?
You may have to move up to a BS2e to take advantage of the bigger EEPROM. The Basic Stamps are still on sale at $49.00, so it might be a good time to upgrade.
Jim
http://www.parallax.com/Portals/0/Downloads/docs/cols/nv/vol3/col/nv87.pdf
Anyway, any type of BS2 can run the GPS Datalogger program right?
Basically...yes. You will have to adjust the Baud Rate setting in the program for the different chips, (see SEROUT command in the manual).
All the 24 pin devices are on sale for $49.00, so go for the one that will suit your need by compaing them here.
