Designing a DC printed circuit board, ground concerns.
Designing a DC printed circuit board…
…Would you tie the outer shell of a USB connector (type B see picture) to the negative or ground of your supply? If so, then would you connect to either the analog ground, or the digital ground to the connectors shell?
I also would ask to only focus on the question and exclude the “chassis” or ‘earth ground” for now. I want to soak it in one topic at a time.
What if the connector is not connected to a host("A") and someone touches the client end("B"). Should I offer some protection against that type of damage?
Surely you ground the client shield if a hand-held battery device but not if a mains powered device? In the mains case you want to prevent a ground loop, but in the hand-held case you want to prevent static-discharge from occuring on the signal lines by arranging the shield to common the device grounds on first connection and take any spark.
(Actually maybe the correct thing to do is ground the client shield via a 10k or so resistor or an RF-choke to soak-up static discharge while preventing significant ground-loop currents. See "Digital Hardware Design", Catt/Walton/Davidson, ISBN 0333259815)
I decided to ask the forums here mostly because I am reading "The Circuit Designers Companion" and it shows various ground loops and I am very leery about changing things that seem or are working.
Peter
