3D models for electronic, electromechanical and mechanical parts
I suspect this will be a work in progress, but is intended to be a list of 3D models helpful for use in designing robots and the like for your Parallax products.
I'll add links as I run across them, adding direct links to models or collections whatever makes the most sense. This list will be intended for files available for free.
Please add to this as you wish, and I hope this helps someone
#1 A nice collection of very nice and detailed parts including the HS-322HD servo, PING, Sharp IR distance sensor and a limit switch as well as other stuff
http://www.firstcadlibrary.com/pages/electrical parts.asp
#2 Then there's always 3D Content Central with an untold number of models in as many categories with varying degrees of detail and quality
http://www.3dcontentcentral.com/
#3 Lynxmotion includes standard (typically Hitec) servos, servo accessories and models to all Lynxmotion brackets, sprockets, assorted hardware and robots with other doo-dads
http://www.lynxmotion.com/s-5-ses-3d-models.aspx
#4 PING model in SketchUp by W9GFO
http://forums.parallax.com/showthread.php?135700-PING)))-SketchUp-model
It would be even better if they were in a format that could be imported into SketchUp.
