QuickStart Labels
Phil Pilgrim (PhiPi)
The 2x20 header on the QuickStart board has no silkscreening associated with it to identify the pins. I've created some labels to remedy that situation:
To each of the first four people who email me (address in my profile) a request with a U.S. Mail address, I will send enough labels for ten boards. These are printed with permanent heat-set black resin on durable white polyester, backed with a pressure-sensitive adhesive.
My only request to those who receive the free labels is to evaluate them and provide me with feedback. I'm trying to decide whether to offer them for sale -- probably for around $5 post-paid for ten sets.
I sent you an e-mail.
zappman
I think your labels are much nicer than the ones I've made.
My Brother label maker will print sideways but only one character.
Even my hard to read labels have made it much easier for me to use the QuickStart boards. I think Parallax ought to include a set of labels with each board.
Duane
Thank you!
Labels received in yesterday's mail. I've installed two sets so far (one on a 32k board, one on a 64k board). They fit either board perfectly!
This is going to make things much nicer.
I'll check in as they get more wear and tear.
As far as I am concerned, these "QuickStart Labels" are a must have item for the QuickStart Boards.
Without the labels you must have a copy of the Schematic available, to wire up the QuickStart Boards.
The labels are especially helpful when you get past Pin 27 on the connector, such as "P29, SDA being on Pin 29" while "P28, SCL is on Pin 31"
zappman
