Need a 4 channel ADC...
denno
Good morning...could/would someone direct me to a 4 channel ADC that doesn't cost $30 some dollars. Need the ADC to of course work or interface with the BS2sx.
Thanks....DenO
Thanks....DenO
See Experiments with Renewable Energy page 26 for code examples.
http://www.parallax.com/Portals/0/Downloads/docs/books/edu/Web_EWRE%201.0a.zip.zip
falcon
First, I have used the LTC1298, alot, and I was wondering if you still need to use the 1 Kohm resister between the data_in and the data_out pins like on the LTC1298?
Second, does the Vref get tied to the 5 volt Vdd for the 5 volt reference or is a seperate reference voltage needed? I will not be measuring anything over 5 volts through the analog inputs. More likely nothing over 2.5 volts or 2500 mV.
Thanks...DennO
