opcodes for movi — Parallax Forums
opcodes for movi
RS_JimRS_Jim Posts: 1,777
edited 2011-10-01 16:03 in Propeller 1
I was recently frustrated by trying to get the correct opcode information to use in a MOVI instruction so I built the following table:
{{opcodeconstants.spin is a table of opcodes that can be used in conjunction with
the MOVI command for self modifing code. This table can be cut and pasted into the
spin code for a PASM object or used with the file include function of bst. }}
CON
a_ABS    = $151
a_ABSNEG = $159
a_ADD    = $101
a_ADDABS = $111
a_ADDS   = $1a1
a_ADDSX  = $1b1
a_AND    = $0c1
a_ANDN   = $0c9
a_call   = $0b9
a_CMP    = $108
a_CMPSUB = $1c1
A_CMPSX  = $188
a_CMPX   =  $198
a_DJNZ   =  $1c9
A_HUBOP  = $018
a_JMP    = $0b8
a_jmpret = $0b9
A_LOCKCLR = $018
A_LOCKNEW = $019
A_LOCKRET = $018
A_LOCKSET = $018
A_MAX    = $099
A_MAXS   = $089
A_MIN    = $091
A_MINS   = $081
A_MOV    = $141
A_MOVD   = $0a9
A_MOVI   = $0b1
A_MOVS   = $0a1
A_MUXC   = $0e1
A_MUXNC  = $0e9
A_MUXNZ  = $0f9
A_MUXZ   = $0f1
A_NEG    = $149
A_NEGC   = $161
A_NEGNC  = $169
A_NEGNZ  = $179
A_NOP    = $000
A_OR     = $0d1
A_RCL    = $069
A_RCR    = $061
A_RDBYTE = $001
A_RDLONG = $011
A_RDWORD = $009
A_RET    = $0b8
A_REV    = $079
A_ROL    = $049
A_ROR    = $041
A_SAR    = $071
A_SHL    = $059
A_SHR    = $051
A_SUB    = $109
A_SUBABS = $119
A_SUBS   = $1a9
A_SUBSX  = $1b9
A_SUBX   = $199
A_SUMC   = $121
A_SUMNC  = $129
A_SUMNZ  = $139
A_TEST   = $0c0
A_TJNZ   = $1d0
A_TJZ    = $1d8
A_WAITCNT = $1f1
A_WAITPEQ = $1e0
A_WAITPNE = $1e8
A_WAITVID = $1f8
A_WRBYTE  = $000
A_WRLONG  = $010
A_WRWORD = $008
A_XOR    = $0d9
{ if you add the following to any of the commands you create wc,wz wcwz }
A_WC     = 2
A_WZ     = 4
A_WCWZ   = 6
{ example mov tmp1,A_cmp
          add tmp1,A_wcwz
          movi loop,tmp1}
I am finding having this around is rather usefull. I hope is usefull to others.
Jim
