PocketTerml - a great VGA VT100 terminal for RS-232 and RS-485
LoopyByteloose
I finally got PocketTerm up and running on one of my Propeller ProtoBoards. It is a great 640X480 resolution dumb terminal for Linux projects and a variety of other Propeller projects where you don't want to tie up your regular computer with I/O.
And as it implies, it is a device that can fix in a pocket and be brought to a keyboard and VGA (no mouse functions)
If you are interested, take a look at BrielComputers.com. Bare boards are $18USD. Kits $60USD. Or just use a ProtoBoard and figure out RS-232 for yourself.
I really needed this for several Linux projects, a RS-485 project, a DS Tini computer, a Linux router project, Propeller Forth, and a headless Linux server with maybe the PandaBoard.
And, I modifed and loaded the software into the Propeller with BST - something new for me as well.
There's an option for a ZIGBEE connection as well in case I want to run these totally remote and the unit is normally fitted with it's own switcher supply so it can run from 9 right up to 70V supply.
The headshell case is from PacTec and normally has a square cutout on the back through which I connect my keyboard and wire my communications and power directly into the screw terminals with provision for strain relief.
I really made these up quickly to showcase some other products and needed to drive at least 6 monitors but if there is some interest I might make these available either in kit form or fully assembled.
