SPI flash goes to Quad-DDR, 66MB/s — Parallax Forums
jmgjmg Posts: 15,200
edited 2011-10-01 09:50 in Propeller 1
Spansion have new SPI flash, that does DDR reads, so gets 66Mbytes/sec, from a 66MHz clock on a Quad interfaced 8 pin package.
http://www.eetimes.com/electronics-products/electronic-product-reviews/memory-products/4228497/Spansion-claims-world-s-fastest-serial-flash-memory
http://www.spansion.com/Support/Datasheets/S25FL128S_256S_00.pdf
Hopefully, the Prop II will have the simple hardware-level interface needed to take full advantage of this memory bandwidth ?
A small package, with flexible FLASH sizes, and 66Mbytes / sec, is a natural complement.
  • RaymanRayman Posts: 16,276
    edited 2011-09-30 13:08
    That would be a real winner!
  • jazzedjazzed Posts: 11,803
    edited 2011-09-30 13:26
    It would make a difference when used by a micro that's fast enough.
    edited 2011-09-30 14:16
    Hopefully not, if it means wasting silicon on a dedicated protocol engine. Memory access protocols go obsolete way quicker than the Prop I or II ever will.
  • jmgjmg Posts: 15,200
    edited 2011-09-30 15:09
    ? SPI is already much older then Prop 1, and it is clearly not going away.
    DDR is also older than Prop 1, so these ideas are not fashion, they are fundamental.
    It does not need a large silicon area, just a serialiser, and maybe some simple DMA.
    Given Prop II does NOT have any FLASH code memory itself, giving smarter access to extenal flash would seem a no-brainer. (to me)
    edited 2011-09-30 16:42
    A protocol-agnostic input serializer -- something like the reverse of waitvid -- would be great, and I expect to see it implemented in the Prop II. But, beyond that, no. Don't forget, anything that's protocol-specific has to be replicated across all the chip's I/O pins. It's not like a PIC or AVR, where only certain pins support certain peripherals.
    edited 2011-09-30 16:44
    We really do need that. I think somebody called it a deserializer. I remember Saphiea discussing this with Chip. I sure hope it's included in Prop 2.
    edited 2011-10-01 05:18
    Another option that would make things faster is a wrlong and rdlong that automatically increases the source or destination register by 4...
    edited 2011-10-01 07:39
    IIRC, index autoincrement will be a Prop II feature, as originally requested by Bill Henning to make LMM more efficient.
    And as requested by many others for other uses! :)
    There are serializer/deserializer (SERDES) instructions (list posted previously), but i have no idea how to use them.
