Question about PING))) Demo code for BS1
Hi all,
This is a complete noob question. I just got my PING))) and HB25 today for a Halloween project and want to play with them a bit to figure out how they work and such.
I plunked the PING))) BS1 demo code into my Prop-1. The green LED is on, but I see nothing but zeros in the window that comes up in my stamp editor. Should the numbers be changing as an object is in view at varying distances? Seems like it should.
Rob
Rob
If you have the PING))) connected to I/O pins 6 or 7, you should leave off the pullup/pulldown jumper since the PING))) has its own pulldown resistor.
I'll pull thejumper tonight and see if that does the trick.
Thanks!
Now to figure out the HB25
