PropBasic Confusion?
I try to attach a MDOG LCD to a C3 Board.
I wrote the following init code:
Why? 920 longs -> too much for cog memory?
273 lines of code? no, spin file has 391 lines?
BTW what does the speed param mean in shiftout? MCLK time?
Friedrich
' ---------------------------------------------------------------------- ' File...... C3_SPI.pbas ' Author.... fgvissel 28.09.2011 ' for C3 Board with 6,26 MHz X-tal ' ====================================================================== ' ----- Device Settings ------------------------------------------------ DEVICE P8X32A, XTAL1, PLL16X XIN 6_250_000 ' ----- Conditional Compilation Symbols -------------------------------- ' ----- Constants ------------------------------------------------------ ' ----- IO Pins -------------------------------------------------------- PSI_CLR Pin 25 High PSI_CLK Pin 8 High RS Pin 10 Output MOSI Pin 9 Output MCLK Pin 11 Output ' ----- Shared (HUB) Variables (Byte, Word, Long) ---------------------- ' ----- User Data (DATA, WDATA, LDATA, FILE) --------------------------- ' ----- TASK Definitions ----------------------------------------------- ' ----- Local Variables (LONG only) ------------------------------------ channel var long ' ----- SUB and FUNC Definitions --------------------------------------- DelayMS SUB 1 DelayUS SUB 1 ' ====================================================================== PROGRAM Start Start: low PSI_CLR 'reset CS Counter in C3 high PSI_CLR channel = 0 'select S6 device do low PSI_CLK high PSI_CLK inc channel loop until channel = 6 low RS 'Init LCD delayMS 40 shiftout MOSI, MCLK, MSBFIRST,$39 delayUS 27 shiftout MOSI, MCLK, MSBFIRST,$14 delayUS 27 shiftout MOSI, MCLK, MSBFIRST,$55 delayUS 27 shiftout MOSI, MCLK, MSBFIRST,$6D delayUS 27 shiftout MOSI, MCLK, MSBFIRST,$78 delayUS 27 shiftout MOSI, MCLK, MSBFIRST,$38 delayUS 27 shiftout MOSI, MCLK, MSBFIRST,$0F delayUS 27 shiftout MOSI, MCLK, MSBFIRST,$06 delayUS 27 shiftout MOSI, MCLK, MSBFIRST,$41 delayUS 32 high RS Main: ' program code GOTO Main END ' ----- SUB and FUNC Code ---------------------------------------------- SUB delayMS pause __param1 ENDSUB SUB delayUS pauseus __param1 ENDSUB ' ----- TASK Code ------------------------------------------------------ ' ----------------------------------------------------------------------This compiles ok, loading with bstc to the c3 yields:
---------- Download to RAM ---------- Brads Spin Tool Compiler v0.15.3 - Copyright 2008,2009 All rights reserved Compiled for i386 Win32 at 08:17:48 on 2009/07/20 Loading Object C3_SPI Program size is 920 longs Compiled 273 Lines of Code in 0,016 Seconds We found a Propeller Version 1 Propeller Load took 0,654 Seconds Output completed (0 sec consumed) - Normal TerminationProgram runs ok, see LA01 output (BTW The DOG LCD does not init correctly??)
Friedrich
The speed param is the clock speed multiplier.
Bean
