The new led strips
The guide lines allow for some non parallax chat and i feel parallax members are some of the best,so here goes with my questions.
I read that while regular leds require constant current sources the new led strips need a constant voltage source.
Q1. Is a regulated power supply the same thing as a constant voltage source?
Q2. Does any one know how to explain the two in a way that is easy to understand.
Q3. And if a constant current source is required for regular leds,,,then why do we all use regular power supplies ,,to light them,,,and it seems to work fine. ( ie what may the writer have meant to say that)
Thanks , jonw
Thanks , jonw
A2. The forward voltage of LEDs can vary a little from part to part, from batch to batch, or with temperature. The current vs. voltage curve takes a steep excursion around the forward voltage -- as it does with any diode. So regulating an LED's voltage is a risky proposition, due to the slope of the current curve near Vfwd. For that reason alone, it's always best to regulate the current instead of the voltage.
A3. The reason "regular power supplies" work with LEDs is due to the resistor always placed in series with one (or a string) of them to limit the current.
So the voltage would be set to overcome the highest Vfwd in the string, thus ensuring a desired current ("current compliance")?
So, no matter what Vfwd might exist in the string, the current through the string will be limited to 'X' amount.
But won't that still result in variations of brightness, and isn't that what is being sought to avoid?
But I still do not really under the difference between CC and CV supplies. Is it the feedback or the way its regulated that makes the difference.
One person explained that a constant current source will have a constant current ( sounds reasonable right ) But does that mean the voltage varies to keep the current steady?
Thanks for all the kind replys.
So phil the voltage will change,,,to keep the current steady? ( sorry to repeat )
