BOE question with Propeller
JohnR2010
I have a project that connects to a 24volt DC power supply that is also used to run two Von Wise Actuators. The Von Wise Actuators are DC motors and my circuit doesnt do anything with them but I do pull form the same power supply used to drive them. These motors do create some noise and I have a filtering cap across my DC voltage regulator but randomly once every 3 or 4 days my propeller resets when these motors are running. Im 99.9% sure this is not a code problem but I do think it is a power problem. I have the BOE circuit enabled by pulling it low to ground. My question is this. If I tie the BOE to VDD (Disable BOE) will this make the propeller P8X32A-D40 more tolerant of a low voltage spike or help with my reset problem? Will the Propeller continue to run at a low voltage below 3.3 volts if I disable BOE?
