Elementary Background Task to control Stingray Motors in PropBasic — Parallax Forums
FriedVFriedV Posts: 77
edited 2011-09-25 11:09 in Propeller 1
Something to play with, based on the Stingray Propeller board.
Friedrich
' File......  MotCtl.pbas
' Author....  fgvissel  23.09.2011
' based on the SRMotorControl Object by Nico Schoemaker
' mind the 10 MHz Propeller
' ----- Device Settings ------------------------------------------------
  DEVICE P8X32A, XTAL1, PLL16X
  XIN 6_250_000
' ----- Conditional Compilation Symbols --------------------------------
' ----- Constants ------------------------------------------------------
' ----- IO Pins --------------------------------------------------------
' ----- Shared (HUB) Variables (Byte, Word, Long) ----------------------
  hbPeriodTicks     hub long = 0
  hbCommand         hub long = 3  'Sync with PWM cog
  hbSpeedL          hub long = 0
  hbSpeedR          hub long = 0
  hbRampDelay       hub long = 0
' ----- User Data (DATA, WDATA, LDATA, FILE) ---------------------------
' ----- TASK Definitions -----------------------------------------------
  PWM TASK AUTO
' ----- Local Variables (LONG only) ------------------------------------
  t1 var long   'for intermediate temp results
' ----- SUB and FUNC Definitions ---------------------------------------
  MoveForward     SUB 1
  MoveBackward    SUB 1
  SetRampDelay    SUB 1
PROGRAM Start
Start:
  t1 = _FREQ / 1000          'PWM frequency is 1 kHz, Period 1 msec
  wrlong hbPeriodTicks, t1
  wrlong hbSpeedL,    0      'clear command
  wrlong hbSpeedR,    0
  wrlong hbRampDelay, 0
  wrlong hbCommand,   0      'Start Background PWM Task
'------------------Simple Testframe for Stingray Motors ---------------
Main:
  SetRampDelay 10
  do
    MoveBackward 100
    pause 3000
    MoveForward 100
    pause 3000
  loop
END
' ----- SUB and FUNC Code ----------------------------------------------
  SUB MoveForward 'Speed
    do                              'Wait forPWM cog to finish command
      rdlong hbCommand, t1
    loop until t1 = 0
    __param1 = __param1 MIN   0     'send new command, forward speed 0 - 100
    __param1 = __param1 MAX 100
    wrlong hbSpeedL, __param1
    wrlong hbSpeedR, __param1
    wrlong hbCommand, 1
  ENDSUB
  SUB MoveBackward 'Speed
    loop until t1 = 0
    __param1 = __param1 MIN   0    'send new command, backward speed0 - 100
    __param1 = - __param1
    wrlong hbCommand, 1
  ENDSUB
  SUB SetRampDelay  'RampDelay
    wrlong hbRampDelay, __param1
  ENDSUB
' ----- TASK Code ------------------------------------------------------
  TASK PWM
    SetOutputMask     SUB
    GetCommand        SUB
    GetHubCommand     SUB
    t1                var long
    delay             var long
    SlicDur           var long
    SliceCount        var long
    OutputMask        var long
    Command           var long
    SpeedL            var long
    curSpeedL         var long
    curAbsSpeedL      var long
    SpeedR            var long
    curSpeedR         var long
    curAbsSpeedR      var long
    RampDelay         var long
    curRampDelay      var long
'---Code---
    t1    = %1111                       'Output Bits 24..27
    t1    = t1 << 24                    'are set to 0 on cogstart
    dira  = t1
    do
      rdlong hbCommand, Command         'Init, Sync with cog 0
    loop until Command <> 3
    rdlong hbPeriodTicks, SlicDur       'read clockticks for one period (100 Slices)
    SlicDur       = SlicDur / 100       '1/100 period ticks
    SliceCount    = 100
    SpeedL        = 0                   'init all Speeds to 0
    SpeedR        = 0
    RampDelay     = 0
    curSpeedL     = 0
    curSpeedR     = 0
    delay         = SlicDur              'set delay to the end of 1. period slice
    delay         = delay + cnt
    do                                          'endless loop, create PWM
      do
        do                                      'do forever, main PWM loop
          do                                    'inner loop, run one slice
            for SliceCount = 100 to 0 step -1
              SetOutputMask                     'based on current values
              outa = OutputMask << 24           'set pins for current Slice
              waitcnt delay, SlicDur            'wait till end of current slice
            next
            GetHubCommand
          loop while RampDelay = 0              'no ramp delay, loop
        dec curRampDelay
      loop while curRampDelay > 0               'loop for RamDelay
      curRampDelay = RampDelay                  'set new RampDelay
      if curSpeedL < SpeedL then
        inc curSpeedL
      elseif curSpeedL > SpeedL then
        dec curSpeedL
      endif
      if curSpeedR < SpeedR then
        inc curSpeedR
      elseif curSpeedR > SpeedR then
        dec curSpeedR
      endif
    loop
'---SUBs---
    SUB SetOutputMask
      OutputMask = %0000                  'OutputMask = 0
      if curSpeedL < 0  then
        OutputMask = OutputMask | %0001   'LM back, leave RM alone
      elseif curSpeedL = 0 then           '             bit 24 = 1
        OutputMask = OutputMask | %0011   'stop left motor
      elseif curSpeedL > 0 then
        OutputMask = OutputMask | %0010   'set left motor to forward
      endif
      curAbsSpeedL = abs curSpeedL
      if SliceCount > curAbsSpeedL then
        OutputMask = OutputMask | %0011   'Stop left motor
      endif
      if curSpeedR < 0 then
        OutputMask = OutputMask | %1000   'set right motor to backward
      elseif curSpeedR = 0 then           '                 bit 27 = 1
        OutputMask = OutputMask | %1100   'stop right motor
      elseif curSpeedR > 0 then
        OutputMask = OutputMask | %0100   'set right motor to forward
      endif
      curAbsSpeedR = abs curSpeedR
      if SliceCount > curAbsSpeedR then
        OutputMask = OutputMask | %1100   'Stop right motor
      endif
    ENDSUB
    SUB GetHubCommand
      rdlong hbcommand, command           'get new command
      if command <> 0 then
        rdlong hbSpeedL,      SpeedL
        rdlong hbSpeedR,      SpeedR
        rdlong hbRampDelay,   RampDelay
      endif
      if Rampdelay = 0 then
        curSpeedL = SpeedL
        curSpeedR = SpeedR
      endif
      Command = 0                         'set Bit0 = 0
      wrlong hbCommand,    Command   'sig caller that processing is finished
    ENDSUB
  ENDTASK
  • JonnyMacJonnyMac Posts: 9,839
    edited 2011-09-24 14:14
    Since you have two motors you may want to take advantage of the counters; using an synchronized loop you can get precise PWM with very little trouble. The counter takes care of creating the output pulse which gives you plenty of time in the loop for adjustment calculations. The attached object is written in Spin but should be pretty easy to translate to PropBASIC.
  • FriedVFriedV Posts: 77
    Very elegant solution, thx Jon!
    Fried
