Menu on uoled128 looking for examples
Hello All,
Does anyone know of some examples in the OBEX possibly that would demonstrate a simple menu that would scroll up and down with button presses. I have 3 buttons hooked up that are pulled high with a press (Up, Down and Select). I'll post my code of how I thought it might work so you can see how far off I am. I am sure I am headed in the wrong direction with this code.
When the uOLED is turned on I would like it to display text in Yellow the default mode would be Mode 1 which will display Red and as push buttons are pressed the next line would change from Yellow to Red so you know what line you are on at anytime you could press Select button to jump to that Method.
Thanks for any input.
-Ron
PUB TestButtons 'ModeNumber is a global variable
OLED.INIT
SETUP
ModeNumber := 1
dira[LED] := 1 'LED on pin 15 for debugging
dira[Up..Down] := 0
OLED.FTEXT(0,1, 2, 255,0,0, string("Mode 1 Display"),0) 'red
OLED.FTEXT(0,3, 2, 255,255,0, string("Mode 2 Display"),0) 'yellow
OLED.FTEXT(0,5, 2, 255,255,0, string("Mode 3 Display"),0)
OLED.FTEXT(0,7, 2, 255,255,0, string("Mode 4 Display"),0)
OLED.FTEXT(0,9, 2, 255,255,0, string("Mode 5 Display"),0)
DELAY.PauseSec(10)
repeat
if ina[Down] == 1
ModeNumber++
elseif ina[Up] == 1
ModeNumber--
case ModeNumber
1: OLED.FTEXT(0,1, 2, 255,0,0, string("Mode 1 Display"),0)
2: OLED.FTEXT(0,3, 2, 255,0,0, string("Mode 2 Display"),0)
3: OLED.FTEXT(0,5, 2, 255,0,0, string("Mode 3 Display"),0)
4: OLED.FTEXT(0,7, 2, 255,0,0, string("Mode 4 Display"),0)
5: OLED.FTEXT(0,9, 2, 255,0,0, string("Mode 5 Display"),0)
-Ron
