Circuit for smoothing power supply output - help please
I am designing a board that will use the Propeller and Wiznet module powered with 3.3v and other ICs at 5v. I am using the Propeller Proto Board USB design as the basis for my board power supply. I'll have a LM1086-3.3 providing the regulated 3.3v supply, but instead of that being supplied by the output of a LM1086-5 on-board, which itself is supplied by 6-9v DC from off-board, I will be using an off-board regulated 5v supply, which means I won't be using the LM1086-5 in my board design. This all sounds good so far. Unfortunately, the 5v supply is a 100A 5V supply, and when I looked at the output with an o-scope it looks like there is about 200mV PtP noise on the output. I'm concerned that if I use that 5v source without further smoothing, it will cause me problems.
Question: can anyone point me towards a circuit design different than the typical (such as the LM1086) regulator, but more like a filter that will smooth the output of my 5V supply. My first thought was to just put a big (22000uF) electrolytic capacitor at the 5V connector; then I read a bit about a Pi network. What shall I use? Thanks for any help.
Will you please quantify what a small inductor value is?
Would the 10-22uF cap be a specific type? Aluminum electolytic, tantalum?
Is the 0.01 uF cap a ceramic?
Thanks.
This will be driving a LM1086-3.3 (which shouldn't be a problem, the 3.3v out should be clean (with proper capacitors as specified in manufacturer datasheet) and 74HCT595 shift registers - which is where I'm concerned the noise might be a problem, even with 0.1uF ceramic decoupling capacitors close to the VCC/GND pins.
Good luck with it, and please let us know how it works out.
What I've done is to give myself an option on the board design: with one jumper setting I can bring the +5V in from the 100A supply, with a 10uF and 0.01uF ceramic (the LM1086 data sheet calls for 10uF tantalum on both input and output, so I thought I'd use that value - if the forum wisdom is to go even larger than the manufacturer's recommendation I can do that) to ground, then out to the 74HCT595 shift registers and to Vin of the LM1076-3.3.
In case that is too noisy, another jumper setting will allow me to bring in 6-9V from another supply (wall-wart most likely) and drive a LN1086-5, which will then drive the '595s and the LM1086-3.3.
Is there any problem with the first setting, where I would be putting +5V on Vout of the LM1086-5, and leaving Vin floating?
Here's a schematic of what I mean. Thanks for the advice & help.
