WizNet visiting Parallax
We are working on a new version of the Spinneret Web Server, and we have a few people from WizNet over discussing the best ways to use the W5200. While they are here, do any of you have any questions you want to ask?
Thank you,
David Carrier
Parallax Inc.
Thank you,
David Carrier
Parallax Inc.
Does WizNet have any plans for a WiFi version of the W5x00??? You know, something that would pretty much just drop onto a Spinner?? Maybe add an antenna or antenna connector??
— David Carrier
Parallax Inc.
Basically it's serial only, 8 sockets instead of 4, and includes a burst mode that I haven't really looked at yet.
Any interest in creating drivers for this?
If you guys can get them, board them, with a Prop, eeprom, xtal & regulators & a couple of diagnostic LEDS then you'd have a real winner! Imagine all the Prop embedded technology you could have around the house! Please just leave it simple and not over-enhance it. IMHO I found the Spinneret tried to be too many things to too many people and left only 4 easily accessible prop pins to do the really interesting stuff!
I'm currently (as we speak) playing with the Roving Networks RN-131C Wifly GSX into a Prop project. But if you had the WizFi210 on a board with a Prop ready to bolt in then I'd definitely consider it (price dependant).
I know I'm reviving an old thread, but hopefully it's not too late to put in a request for the next Spinneret. Could it pretty-please include PoE support? In my ideal incarnation, a new Spinneret would be easily configurable to provide PoE power for my own added circuitry as well.
An option to get 12v or even 24v as well as the 5v/3v3 needed for the Spinneret itself would make it my ideal platform for simple home automation projects.
Electrodude
The W5200 has twice the memory, which is needed to buffer the eight sockets. More importantly it has a very high SPI clock rate, which means that it doesn't need a parallel interface. This will not only increase speed over the current Spinneret Web Server, but it will do so on the SPI bus, freeing up the pins that were formerly allocated to the parallel bus.
— David Carrier
Parallax Inc.
