Prop reset — Parallax Forums
Prop reset
kthor31kthor31 Posts: 2
edited 2011-09-21 11:37 in Propeller 1
Hi everyone. I have a quick question that I believe does not involve needing to post any prop code. I am just wondering if you can reset the prop from within itself? Is there a way to code this in so that as soon as it starts up it resets like it would if you were in serial terminal and clicked reset prop?
If anyone has any ideas how this can be done please let me know!
    There's a bit in the clock mode register that, when set to 1, resets the Propeller. Check out the description on page 28 of the Propeller Manual. If you're using Spin, the REBOOT statement will set that bit.
