H bridge driver for 2 Pchan and 2 Nchan mosfets
Zap-o
I have searched for quite some time looking for an H bridge driver that will drive 2 P-chan mosfets (high side) and 2 N-chan mosfets (low side). Anyone heard of such a driver? Most I find drive 4 Nchan mosfets for high and low side.
Thanks in advance
Thanks in advance
http://www.datasheetcatalog.org/datasheet/vishay/70611.pdf
I was just wondering if the TIP's in this circuit could be replaced with Mosfets? or is that completely ignorant?
Just wondering,
like I say, I know just enough to be dangerous..
-Tommy
Ttailspin - That schematic would almost work with mosfets in fact it would work but would require a few adjustments.
All together I suppose there is no driver or at the least its not very common to do as I am intending on doing - thus the shortage of driver.
Here is the Fairchild MOSFET driver:
http://www.fairchildsemi.com/ds/FA/FAN3268.pdf
Alex
The optocoupler solution would be ok for very low switching speeds. When you switch the MOSFET gate you're switching a large capacitor. The higher the speed the more power you need. That would require a large transistor in the optocoupler. Plus the push-pull instead of one transistor and a resistor to better control the on/off conditions hence to avoid the state when both MOSFETs are on at the same time.
My circuit needs to be cheap (currently I am driving the h-bridge with Comparators)
10 Amps at 15 Volts running through a 10 foot cable means NO PWM.
Perhaps this afternoon ill post a schematic
Why 10A/15V means no PWM?
Well PWM 'ing 10amps through a 10Foot cable will radiate some noise. You ever hear a power line running, of course that is a hell of a lot more power, but its the same idea. I also have very sensitive analog signals running in that same cable so I want to keep noise minimal.
Not to mention my PCB is small and I cant afford to heat up the ICs on that board. So I use a Mosfet located off the PCB to control the current in an analog fashion (no PWM). The H-bridge just sets the direction of current.
For 5 to 15v look at the IR2301 as a dip, or the IRS2301 as a SO-8
Or possibly a LMH6644 and save 3 pins on the micro
Obviously you'll have coupling to your other wires due to the mutual capacitance and inductance in your cable. It's not the voltage or current that cause the coupling but the edges when FETs switch. You could de-Q it a little by a series power resistor...
If I understand it correctly you want to control these MOSFETs in the linear region? Do you want to control the current and retain the voltage level or the other way around?
No I want to use my h-bridge just simply to set the direction of current. So that the mosfets in the h-bridge will be either fully on or fully off. This keeps the heat off the PCB. The current is controlled by another mosfet located off the PCB and yea its used in the linear region. Have a look at the crude drawing.
If not the Fairchild part seems good but I'd check the FETs' datasheets to see if it's strong enough to drive the gates. I'm not sure if the NMOS high side driver Capt Quirk suggested can be used to drive the PMOS though. It would definitely have to be connected differently than the datasheets suggest for the high side NMOS.
