Any Eagle libraries for .5" and .6" DIP sensor packages?
I was just wondering if anyone has created an Eagle library for the sensors that use .5" and .6" DIP spacing? I don't expect signals or labels, just the the schematic symbols and board footprints to work from. I know I can create my own, but it would be a first time attempt, and even though I can figure it out, I don't want to stop creating what I am working on to learn a new process that will side track me. In the past I would just use pinheaders in the schematic, and place them very carefully spaced onto the board... but this is slow and I don't always get it right first try. And this time there will be several of them.
I am using the LISY300 Gyro module (.6") and MMA7455 Accelerometer module (.5") and was hoping for something that would fit them. I am sure there are others, but these are the two I am looking for right now.
I hope someone has something they would be willing to share...
Thanks!
Thanks!
http://www.instructables.com/id/How-to-make-a-custom-library-part-in-Eagle-CAD-too/
It's can be a little confusing, but I've added several 'footprints' to my library without much problem. My latest was for a uSD socket and it aligned (and worked) perfectly!
Good luck; it's not that hard.
So thanks again!
Dude, you really need to change your avatar. It's totally inappropriate for a family-friendly forum. Sorry, man, but I wanted to give you a heads-up before the moderators came down on you -- and I have a feeling they might.
