question on GND
Hi
I dont know if this is the right place but I'm developing a device for text overlay by use of a propeller. It recieve it text and commands by a lantronics Xport and sends it to the right BOB4 module. I made a test board with one BOB4 module and that is working fine. Now I need more than 1 BOB4 module on the same prop. So in my print layout I'm designing I got stuck on a question.
As you can see in the specs (see attachement) of the BOB4 the connection 28,29 is video out and 29, 30 is video in. So 29 is GND of the video. They alo mention that you need to connect 29 (what is video GND) to the GND of the power supply. Now when you have multiple BOB4 modules on the same power supply you are connecting the GND of all the camera's that you connect together. That is also the case on the matrix device where the video out is going to. Now when you connect the video gnd together on more then one place you create ground loops??
Is this not the case in this setup ?
Is somone having an other opinion? Can leave the connection to power supply GND from 29?
Thanks for any reacktion.
Stef
Stef
By looking at the guide, I would say that you are ok to link the video grounds together. I may be wrong on this, but you should be ok since neither the prop or the BOB4 seperates digital and analog grounds. (and someone please correct me if I am), but according to page 9 of B4AppGuide.pdf, you might want to follow the rule of using 22ga wire or better, just to be on the safe side.
Phil, to me the propeller backpack seems better than the Basic Stamp 2pe mobo. Do you know if Parallax plans to migrate to the propeller backpack from the 2pe?
Actually, I have a MoBoProp on the drawing board, with the same form-factor as the MoBoStamp-pe. It just needs prioritizing to get it done. One open question is whether to include the AVRs to do A-to-D and PWM, or to rely on the same sigma-delta circuitry and software PWM used by the Backpack. My original MoBoProp prototype omitted the AVRs, and doing so would keep the cost down. Plus, the Backpack seems to work nicely with the TSL1401's analog output. OTOH, the AVRs would provide cog relief and be able to take advantage of already-written firmware. The other question is whether to provide a separate 1/8" stereo connector for A/V output. The MoBoProp would not have all the A/V features of the Backpack, though -- not enough room, not enough Propeller pins.
Loops are only a problem when the loop is relativly large and stuff can get induced into them.
Yes I saw the propeller backpack but I was a bit scared because it only mentioned NTSC video and not PAL. My region is Europe and they use PAL as standard. That is one of the reasons why I chose Bob4. Now the end user is willing to invest, so price is not an issue.
Thanks again for the sugestion.
Toby
So you think it is not a problem tying them together so Video gnd = power supply gns?
Stef
I am constantly amazed at the deals this company dishes out. I should read up more on some of these toys already offered.
Given a free choice on the disign then keeping the dirty grounds sparated away from the clean grounds is allways good. Even on internal bits such as SDRAMs half of the "GNDs" are classed as clean (data) but ground is ground and so all should be used so that all the internal current flow paths are equalized (as should the VDDs). The problem of noise margins shouldn't be a digital problem as this noise would have to aproach half VDD levels but a few mV on the analoge would probably be seen or heard ( I explain these away as a retro "Feature" ;-) )
see the attached spin file for a schematic of what i'm talking about.
I will take your advice in use when I design the pcb layout.
stef
