You've Never Seen a Robot Drive System Like This Before — Parallax Forums
edited 2011-09-19 05:46 in General Discussion
http://spectrum.ieee.org/automaton/robotics/diy/youve-never-seen-a-drive-system-like-this-before
What you're looking here is a hemispherical omnidirectional gimbaled wheel, or HOG wheel. It's nothing more than a black rubber hemisphere that rotates like a spinning top, with servos that can tilt it left and right and forwards and backwards. Powered by this simple drive system, the robot that it's attached to can scoot around the floor in ways that I would have to characterize as "alarmingly fast."
Before I go on about the design, have a look at just what this thing is capable of. Its creator, Curtis Boirum, a grad student at Bradley University, in Peoria, Ill., demoed it at the 2011 RoboGames symposium:
  • graffixgraffix Posts: 389
    edited 2011-09-18 05:43
    Very nice find Ron,Thanks
    edited 2011-09-18 05:49
    How does this do in a controlled sense, simply navigating pylons?
    It does a lot of spinning -- OK, spinning and tumbling.
    There are known "issues".
    [Also, Boirum acknowledges that it's an old idea.]
  • Bill ChennaultBill Chennault Posts: 1,198
    edited 2011-09-18 08:04
    Ron--
    Pretty amazing. I wonder what would happen if there were THREE hemispheres and the outboard wheels were ditched?
    --Bill
    edited 2011-09-18 10:30
    Ron--
    --Bill
    Also my first question on seeing the video.
  • $WMc%$WMc% Posts: 1,884
    edited 2011-09-18 10:57
    Did someone say HEMi ?
    Nice find Ron
    edited 2011-09-18 12:51
    $WMc%--
    --Bill
    edited 2011-09-18 17:02
    Hello Bill...
    A little different hemi than where use to, But a cool one at that.
    I think it should be called a SPHERICAL drive since it runs on the out-side of the wheel and not the inside.
    Heres the difference between outside and inside
    480 x 302 - 18K
    411 x 317 - 21K
    855 x 570 - 64K
    edited 2011-09-18 17:29
    Walt--
    Those are the most beautiful pictures I have ever seen in my life. Sox and Martin should be immortalized.
    --Bill
  • W9GFOW9GFO Posts: 4,010
    edited 2011-09-18 17:43
    Pffftttt! Only two valves per cylinder!
    Just kidding!
    That drive system reminds me of the Voith Schneider drive. Someday I'd like to build a wheeled version... someday.
    edited 2011-09-18 21:03
    That is really unique and very clever. One idea that comes to mind to utilize the concept is to use it for the positioning mechanism for a piece of paper in a drawing machine. Have the mount for the HOG wheel fixed mounted with a piece of paper under the wheel and then also have a pen fixed mounted over the paper. The HOG wheel could move the paper around while the pen lifts up or down to draw. Might have to use 2 HOG wheels to prevent errant travel of of the paper with one wheel's tilt adjustments.
    We discussed this back on the Robotics sub-forum a few months ago. I thought Erco's reply was pretty funny:
    http://forums.parallax.com/showthread.php?132872-Singularity-Drive-System&p=1016570#post1016570
