Explain GPS to me. — Parallax Forums
Explain GPS to me.
jdoleckijdolecki Posts: 726
edited 2011-09-15 14:04 in General Discussion
Could someone explain or tell me were to find info.
I dont understand how to navigate between 2 GPS points.
If my bot is at one point and I want to go to another point how do I do that?
thanks
  • Ray0665Ray0665 Posts: 231
    edited 2011-09-15 08:50
    Her is some interesting reading from DPRG.
    While it talks about a specific challenge the article includes all the theory and math you might need.
    http://www.geology.smu.edu/~dpa-www/robo/challenge/index.html
    Have fun
    edited 2011-09-15 08:52
    jdolecki wrote: »
    If my bot is at one point and I want to go to another point how do I do that? thanks
    Good one... google robomagellan and start searching
  • tonyp12tonyp12 Posts: 1,951
    edited 2011-09-15 08:54
    Unless your bot has a digital compass, I guess it need to start driving straight forward and check if it's going at an angle to destination and start steering.
  • RDL2004RDL2004 Posts: 2,554
    edited 2011-09-15 09:15
    Bear in mind that the average GPS receiver has positional accuracy measured in meters. So without a specialized or military GPS, a bot will be able to navigate from one end of a street to the other, but will be totally lost in the backyard.
    edited 2011-09-15 11:42
    I'm working on a GPS project myself. I started with GPS Float Demo. I modified it to use Lonesock's F32 which saves a cog. I also use a four port serial object that save a second cog.
    The price of fewer cogs came at messier code. I had to move many of the child objects into the parent object so I could use a single serial driver.
    GPS Float has methods for computing course and distance. As other's have said, you'll need additional navigational aids besides GPS to keep your robot on course.
    I plan on starting a thread today about my project (GPS Pedometer).
    Duane
    Not sure if it will help at all, but I posted some Handheld GPS code that does some "great circle" math for distance and direction finding.
