PropBasic LMM issue
I have build an environment with Edit+ to compile PropBasic files:
When loading the spin file into the bst ide, all is fine.
When I leave out the LMM parameter, all is fine also.
Can someone elude me?
Thx, Fried
@echo off "c:\program files (x86)\Propbasic\PropBasic-bst.exe" %1.pbas > %1.lst if exist %1.err ( type %1.err ) else ( echo --------- No Errors --------- )The following file compiles fine:
' ---------------------------------------------------------------------- ' ----- Device Settings ------------------------------------------------ DEVICE P8X32A, XTAL1, PLL16X XIN 5_000_000 ' ----- IO Pins -------------------------------------------------------- P0 Pin 0 Low PROGRAM Start LMM Start: ' setup code Main: toggle P0 goto main END ' ----------------------------------------------------------------------It crashes when trying to load it to the Propeller:
Thx, Fried
If you are trying to load it into the Propeller using the Parallax tools it won't work.
The parallax tools do not support @@@ nor do they support pasm code longer than 512 instructions.
You must use BST to load LMM code.
Bean
I'm now beginning a real project, a balancing bot based on Parallax's Stingray kit.
After trying Spin & Catalina C i'm going to stick with your Propbasic, it is simply the fastest.
Now I will try to integrate PASD (should not be a problem) and also Viewport.
So I need the BST IDE anyway, I will call it directly from Edit+, not using the bstl command line.
I intend to use the Floating Point Co-Processor uM-FPU v3.1,so I hope the math will be taken care of.
Fried
