Easy concept for breaking a 'beam' to trigger Prop?
T Chap
I have an application where I need to detect a person walking through an area. A regular motion sensor will not work as it will pick up people outside of the area to monitor. The Ping is perfect in most cases, except in this case it cannot be mounted in the cabinets as the two metal parts would not be acceptable cosmetically, nor can the Ping function if recessed. If recessed, the sound reflects back too easily and false triggers. Mounting the Ping on the ceiling is not an option.
Floor mats are not an option. Another idea that has been accepted is to drill a 1/4" hole in both cabinets, and shine a laser diode(pointer) through the opening from one side to the other, and detect the light on the other end.
The use of hands is not an option, it has to detect the person without an effort being made by the person.
Can anyone think of another method to detect a person within 3 feet of some cabinets without having a visible sensor sticking out?
If using the laser diode(LED actually?), what is a good method to detect with the Prop as the controller?
It looks like the sensitivity is adjustable. I have not used one yet, but I hear they can be used behind a wall.
Or, instead of a laser you could have an IR LED pulsing at 38 kHz and a receiver module on the other side for an optical break-beam detector.
Have you tried shielding a PIR sensor in a tube? And/or removing the fresnel lens? Some kind of blinders or shuttering could be applied here.
I will hook up and test the 38k devices now, I have used them very reliably in short distances ( inches ) to detect a break, but we are talking about 8' in this case, seems the reflections could be an issue. Will let you know in a bit.
BTW, this is 3" off a marble floor, distance between cabinets is 80".
I think the laser idea might be the best idea, very directional, doesn't pick up the door in the vicinity.
Connect the TAB pin to GND. Connect the other side to a 10K, the 10K to 5V. At the junction of the pin to the 10K it reads 5V, and with the pointer on it it reads 0.2V. Seems like a nice solution. Just need to build a mount for the laser/led device to allow pointing it.
Thanks for the advice.
A 38K modulated IR should work at 80". My TV remote does.
Duane
Well... they'll learn, won't they? :-) No actually, laser pointers in the US are less than .5mw in strength for a reason... it's actually safe! No permant damage will occur if someone happens to look directly into the beam of a typical Class I laser pointer. They might be temporarily blinded while their retina readjusts to the normal light levels, but no tissue damage will result.
Class II and greater lasers require FDA approval for use, so you won't generally find them available and they would certainly be way over powered for this type of application. (In fact, a Class II laser could be used for over 1/2" mile detection, if needed. A Class I laser will work for 50 feet in the daylight.)
Bill
Bill,
I take your word for it. So how long can I stare directly into the beam?
I think I've heard that Class I pointer are supposed to be "eye safe". They just seem so darn bright.
I've watched kids who get a new flashlight as a present. One of the first things they do is hold up the light directly in front of an eye (pointing into their eye). (I've seen this happen many times.)
I just worry about kids doing dumb things with a laser (I think it's a good thing I didn't have one as a kid).
Duane
I like the adjustable laser. Thanks for taking time to post pictures.
Duane
