how to use the sine table. example please.
Something simple like draw a sine wave on a graph if you will.
an x and a y.
one full wave. all positive(easy prop math) length like 1024 and highth like 2048. (mr. prop has got enough numbers, is a height/amplatue of 8192 or 16384 easier?). so basicly 1024 coordinates. that i can save/use somewhere to make a graph. something simple to learn from. thanks
can someone do it?? the highest math i've ever taken was algerbra 1. (sucky childhood)
i'm trying to learn sin/cos but its a bit nutty for me. i get the triangle bits, but how to apply or effectivly use the functions, i haven't. but i don't really have the time. its hard enough finding time to play electronics or watch the news.
an x and a y.
One of the best applications I can think of is to generate real sine waves. You need three waves that are 120 degrees apart to drive 3 phase brushless motors (like the ones used in CD players and R/C airplanes)
byteloose: they are (i think) really useful. not just for signal generation but for other stuffs, liiiike that might involve something moving in a circle(or similar), or triangle stuff(like finding location). what exactly however i'm not sure :-) i'm still grass-hoppa :-)
i imagen its..... like on my mill i have two rotarty tables. most people are like why?!?! i'm like so i can cut this fancey cut without haveing to use a cnc controller :-) and they are like wooah you can do that? never would have though that could do that.... hecne why i wish they would add more to that 'PE kit labs' sticky thread!!!!! (finish up the prop1 education before prop 2 so when prop 2 comes i'll be able to understand all the new stuff)
Speed controllers for brushless motors are exclusively PWM devices, of course.
but most important is its a lesson on how to access it and make it do something
http://www.tcee.biz/oldrandomstuffkeepallways/sinewave.jpg if the forum tool didn't work
neat-o... that completes today's lesson,
now to go fix my brokewagon ( bet you didn't know volks was german for broke, they had you tricked to uh? to bad america won't build a diesel 50mpg car)
Thanks very much for making this post. I had spent several hours trying to get code from other posts to work and this worked the first time!
Steve
