Doc. errors in Gold Standard file
The Gold Standard Library file FullDuplexSerial_Test1.spin has some typos/errors:
"these are pins are usually used by the Propeller" should read "these pins are usually used by the Propeller".
and the connection diagram shows the RX and TX lines as joined. They are correct in the FullDuplexSerial.spin file it calls.
There is a discrepancy in FullDuplexSerial.spin, the comments refer to FullDuplexSerial1.2.spin.
The same problems apply to FullDuplexSerial_Test2.spin.
Such files should go through a proper internal review process before they are made available, because of the high standard implied by the name, "Gold Standard".
Thank you for finding these typos in the Gold Standard object! I've pulled it down and am going through it again with a fine tooth comb. I'll have it reposted shortly
Thanks again,
Daniel
