BS2SX Not Sending Signal?
Hello guys, I'm using a BS2SX. When I use it on the Stamps in Class board it works fine (sends the appropriate signal) however, I want to shrink the size of the setup so I put it on my own custom breadboard but for some reason the micro-controller no longer sends a signal (LED doesn't flash). I bought this voltage regulator and I have vss on the bs2sx connected to its ground and V_out connected to VDD on the board. Voltage across the wires reads 4.56 V on a voltmeter. What am I doing wrong? Can you guys help me figure out why it doesn't send a signal on my setup?
Oh and I'm trying to send a signal through pin 15 in case that matters. I've checked all my wires thoroughly, solder's all good and they're all in the right places.
Thanks in advance
Thanks in advance
How about generating a schematic from your wiring and posting that (not a schematic of what you think you have).
Just as one example of what you're not telling us is that the datasheet for your regulator says that a minimum output capacitor of 22uF must be provided or the regulator may not work properly. In fact, an output voltage of 4.56V is way too low for normal operation of the regulator and suggests that something is wrong there. If, by 4.56V, you mean the signal wires (pin 15 and Vss), that's probably correct. That would be a high logic level. A low logic level is on the order of 0.5V.
One really noob question though (sorry I'm relatively new to this stuff): the LED's ground would just go to the micro controller's VSS correct?
To see if the microcontroller is sending signal or not I'm just placing an LED at the pins n seeing if it lights up. Once again, if I put it on the board of education LED lights up (signal sent) fine.
It shows exactly what to do, that the member could make progress.
You guys have been through 7-8 posts of verbal vaguery already and to no avail.
If the member was familiar with jargon like "common ground" then he wouldn't be posing the questions/dilemma that he has.
If I did not intend for it to help then I would not have posted it.
It's unfortunate, but not surprising, that it was not presented earlier.
[I wonder that, given his "Vin/Vss" note, he may have joined "Vin" to "Vss" to give all of the connections, by interpretation, a "common ground".]
What PJ is saying is... http://www.youtube.com/watch?v=_PdhKMMZbds&feature=player_detailpage#t=233s
Gus & PJ don't mince words!
P.S. I didn't connect Vin to Vss.
Thanks Again.
