usb driver problem and Windows 7 64 bit
I am not able to get communication via usb to serial port on my boe. My pc is Windows 7 64 bit. could it be possible that the driver from parrallax for usb is not compatible with Win 7 64 bit?
I have no problem running the BS2 boards with the Parallax USB to Serial converter with Windows 7 64 bit. Are you using the Parallax USB product?
Try another USB cable for grins.
Are you using the retractable USB cable?
I am using the supplied battery pack that came with the boe-bot - holds 4 AA batteries.
First go to device and printer and click on then find the one that tell which comp port that you are using the serial / usb adapter then click hardware then click the one that says Properites then click the one that says Change settings then click the one that says Drivers then click the one that say UpDate Driver..... Search automatically for updated driver software
After I did this it work now
thank you Publison; you were on the right track.
I just got off the phone with parallax tech support and my aa batteries were the problem.
I put a 9 volt bat in and walla! all is good
cheers
Parallax Tech Support is the reason they are so successful. Top notch!
Now the fun begins!
