AM/FM/SW receiver integrated on a single CMOS chip
From my Elektor-Newsletter:
http://www.elektor.com/news/am-fm-sw-receiver-integrated-on-a-single-cmos.1939613.lynkx?utm_source=UK&utm_medium=email&utm_campaign=news
Manufacture Website: Silicon Labs
http://www.silabs.com/products/audiovideo/amfmreceivers/Pages/Si4840-44.aspx
But the downstream DSP can only do AM and FM (mono and stereo). 'Too bad it's not reprogrammable.
Other than that, it's a very intriguing chip.
Nice to hear, otherwise I wasted my money on that HW-9 QRP CW rig!
Come on, Leon. ANY chip can send smoke signals.
Once.
I stopped listening to SW because the internet made it to easy to listen to radio/media from anywhere on the planet at much higher fidelity.
I don't do podcasts for the same reason that I wouldn't have listened to Radio Moscow if it had been on the telephone as an 800-number. It's no fun that way.
These ICs might be nice for re-vamping old radios for which parts are no longer available.
I thought synchronous detection required a carrier that you could phase-lock to. How does that work for SSB?
Thank you for telling us about this chip. I actually want one. It would be fun to build a radio with this chip. What kind of antenna part do I need for short wave and for the radio in general?
What kind of features should I include? This sounds like a seperate post...
Chuck
Actually you can adjust the selectivity of a DC receiver -- and even limit reception to one sideband or another -- by using a DSP downstream from the I and Q mixers. With separate I and Q outputs, just about any signal can be demodulated, using the right algorithm. That's why I thought it would be nice if the DSP in the Si484x were reprogrammable.
It's on my Drake R8B which I got just in time for the bottom to fall out of international broadcasting. Good fortune never comes with both hands full.
"With the addition of audio phase shift networks, it is possible with synchronous detection to receive SSB, or just one sideband of a DSB signal, by the phasing method. The phasing method is more familiar as a SSB generation method, but the inverse process works equally well for SSB reception.
"To obtain SSB reception, the I and Q audio signals are applied to active audio phase shift networks. The networks have a flat frequency response characteristic but exhibit a phase shift which is frequency dependent. This kind of network is known as an
allpass filter (an I-channel allpass and a Q-channel allpass). These two networks have a nearly constant 90 degree audio phase difference (+/- 3 degrees) over the range 50 Hz - 12kHz, which provides a minimum of 31 dB unwanted sideband suppression over that range."
-- W9GR
I too have a "2010" I have a ICF-SW7600GR. I thought it would be a step up from my ICF-2002 (which had been a solid performer except for its known tone setting anomaly), but not so much as I found the selectable sideband responses horribly unacceptibly asymetrical (misaligned, endemic, this was noted by WRTH, PWBR, and others), unworthy of Sony to say nothing of my own discerning ears.
The Drake R8B left the Sony in the dust - and cost a lot more. I remember having been able to pull out All India Radio on 5980 (5970?) with BBCWS booming beside it on 5975 like it wasn't even there.
According to the info I've been able to glean from the web, the '909 has a BFO that's active during SSB reception, so you should be able to receive CW in SSB mode without a problem.
Pricing and Availability
The Si484x multi-band receivers are available in a compact 24-pin SSOP package, enabling cost-efficient, single-sided PCB designs and easy handling in manufacturing lines. Samples and production quantities of the Si484x radio ICs are available now. The Si4840 AM/FM radio IC is priced at $1.81 (USD), and the Si4844 AM/FM/SW radio IC is priced at $1.96 (USD), both in 10,000-unit quantities. To ease radio system design, Silicon Labs offers the Si4840-DEMO and Si4844-DEMO evaluation kits, each priced at $50.00 (USD MSRP). For more information about Silicon Labs’ Si484x wheel-tuned, digital-display radio ICs and to purchase samples and development tools, please visit www.silabs.com/pr/radio-receiver.
@ Chuckz
re: $1.96 (USD), both in 10,000-unit quantities.
One for you and one for me , we only need 9998 more people interested and we can get a great price.
-Tor
How much could someone build a simple radio for? I priced the parts on one of these Hack A Day Alarm Clocks and the price was around $100 due to the cost of the parts people wanted to use.
Even in the jaded Internet Age, a crystal set will still demod AM radio.
Anyone for a ZN414?
The evaluation board is very simple: just the SI4844 chip, some unidentified potted micro driving a small LCD, small amplifier chip for headphones, antenna options and various switches to let you test all the functionality. The included documentation is pretty detailed in how to program it and there is a lot of testing information touting its sensitivity and low noise characteristics. Unfortunately the micro and firmware is totally closed off so you can't hack it, but then again the idea is to get you to buy the chips and make whatever from scratch. The firmware that they wrote to control this is pretty quirky, but good enough to give you the basics of what can be done. The board itself is single sided with a bunch of jumpers, pretty cheap but to the point.
Anyway, the touted sensitivity and low nose is all true! This is an incredible receiver on AM broadcast, FM and SW broadcast. I compared it side by side with my DE1103 and it's definitely nicer to listen to on all bands But don't even think about using the horrible earbuds they provide plug in something high-quality. Because this is AM only, I can't speak to the selectivity well, but the sensitivity seems better than speced almost to the level of the DE1103.
I don't know if I like the whole concept of and pot feeding an 8-bit ADC whch then digitally selects a limited range of frequencies, it's not all that user friendly if you ask me. The BAND selection input is also an ADC with 12 possible values (voltages). This is "analog" interface. But you can ignore all that and feed it whatever frequency you'd like via the 2-wire communication line with you favorite controller chip, uses a rotary encoder and make a "real" (and tiny) radio out of this chip.
The documentation on this is not on the SI site yet, there's just a two page data sheet that doesn't tell you much. I'm still working my way through it, but let me know if I can answer any questions about it.
73,
-w2lp
Digikey have a 24-pin SSOP to DIP adaptor:
24-351000-10-ND
T o n y
